[GeoNetwork-users] Problem with Dublin Core
Hi All!
I've tried new release 2.1 and I have this problem.
When I'm trying to create new Dublin Core metadata, GeoNetwork says
something like that: "Operation could not be performed",
and message appears in the log file:
"2007-10-07 16:39:41,296 ERROR [jeeves.service] - Exception when executing
service
2007-10-07 16:39:41,296 ERROR [jeeves.service] - (C) Exc :
java.lang.IllegalArgumentException: Mismatch between schema and xml: No type
for 'element' : dc:title with parent simpledc
2007-10-07 16:39:41,296 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
  <message>Mismatch between schema and xml: No type for 'element' : dc:title
with parent simpledc</message>
  <class>IllegalArgumentException</class>
  <stack>
    <at class="org.fao.geonet.kernel.schema.MetadataSchema" file="
MetadataSchema.java" line="89" method="getElementType" />
    <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java" line="541"
method="expandElement" />
    <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java" line="464"
method="expandTree" />
    <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java" line="473"
    <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java" line="130"
method="addEditingInfo" />
    <at class="org.fao.geonet.kernel.DataManager" file="DataManager.java"
line="643" method="getMetadata" />
    <at class="org.fao.geonet.services.metadata.GetEditableData" file="
GetEditableData.java" line="72" method="exec" />
    <at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java"
line="238" method="execService" />
line="141" method="execServices" />
    <at class="jeeves.server.dispatchers.ServiceManager" file="
ServiceManager.java" line="372" method="dispatch" />
  </stack>
  <request>
    <language>ru</language>
    <service>metadata.edit</service>
  </request>
  <request>
    <id>8</id>
    <forward service="metadata.create" />
  </request>
</error>
2007-10-07 16:39:41,296 INFO [jeeves.service] - -> dispatching to error
for : metadata.edit
2007-10-07 16:39:41,671 INFO [jeeves.service] - -> transforming with
stylesheet : C:\GeoNetwork\web\geonetwork\/xsl/error.xsl
2007-10-07 16:39:41,765 INFO [jeeves.service] - -> end error
transformation for : metadata.edit
2007-10-07 16:39:41,765 INFO [jeeves.service] - -> error ended for :
metadata.edit".
I have no idea about this problem. I need to fix it up as soon as possible.
Please help me, I'll really appreciate it.
Igor V. Burago
