Hello all,
I have deployed the installation on a server in my network. Everything works fine initially. After a period of time the site doesn’t work. When I try to login or search I get the following error.
I suspect it is related to database connections. Please advise.
Usman
The requested operation could not be performed.
No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error: ** BEGIN NESTED EXCEPTION ** com.mysql.jdbc.CommunicationsException MESSAGE: Communications link failure due to underlying exception: ** BEGIN NESTED EXCEPTION ** java.net.SocketException MESSAGE: Software caused connection abort: socket write error STACKTRACE: java.net.SocketException: Software caused connection abort: socket write error at java.net.SocketOutputStream.socketWrite0(Native Method) at java.net.SocketOutputStream.socketWrite(Unknown Source) at java.net.SocketOutputStream.write(Unknown Source) at java.io.BufferedOutputStream.flushBuffer(Unknown Source) at java.io.BufferedOutputStream.flush(Unknown Source) at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2692) at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2621) at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1552) at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1666) at com.mysql.jdbc.Connection.execSQL(Connection.java:2994) at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:936) at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1030) at jeeves.resources.dbms.Dbms.executeQuery(Dbms.java:372) at jeeves.resources.dbms.Dbms.select(Dbms.java:145) at org.fao.geonet.guiservices.categories.Get.exec(Get.java:52) at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75) at jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119) at jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:104) at jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.java:579) at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:382) at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:608) at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:171) at jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:100) at javax.servlet.http.HttpServlet.service(HttpServlet.java:689) at javax.servlet.http.HttpServlet.service(HttpServlet.java:802) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869) at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664) at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527) at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684) at java.lang.Thread.run(Unknown Source) ** END NESTED EXCEPTION ** Last packet sent to the server was 0 ms ago. STACKTRACE: com.mysql.jdbc.CommunicationsException: Communications link failure due to underlying exception: ** BEGIN NESTED EXCEPTION ** java.net.SocketException MESSAGE: Software caused connection abort: socket write error STACKTRACE: java.net.SocketException: Software caused connection abort: socket write error at java.net.SocketOutputStream.socketWrite0(Native Method) at java.net.SocketOutputStream.socketWrite(Unknown Source) at java.net.SocketOutputStream.write(Unknown Source) at java.io.BufferedOutputStream.flushBuffer(Unknown Source) at java.io.BufferedOutputStream.flush(Unknown Source) at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2692) at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2621) at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1552) at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1666) at com.mysql.jdbc.Connection.execSQL(Connection.java:2994) at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:936) at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1030) at jeeves.resources.dbms.Dbms.executeQuery(Dbms.java:372) at jeeves.resources.dbms.Dbms.select(Dbms.java:145) at org.fao.geonet.guiservices.categories.Get.exec(Get.java:52) at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75) at jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119) at jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:104) at jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.java:579) at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:382) at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:608) at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:171) at jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:100) at javax.servlet.http.HttpServlet.service(HttpServlet.java:689) at javax.servlet.http.HttpServlet.service(HttpServlet.java:802) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869) at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664) at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527) at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684) at java.lang.Thread.run(Unknown Source) ** END NESTED EXCEPTION ** Last packet sent to the server was 0 ms ago. at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2710) at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2621) at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1552) at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1666) at com.mysql.jdbc.Connection.execSQL(Connection.java:2994) at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:936) at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1030) at jeeves.resources.dbms.Dbms.executeQuery(Dbms.java:372) at jeeves.resources.dbms.Dbms.select(Dbms.java:145) at org.fao.geonet.guiservices.categories.Get.exec(Get.java:52) at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75) at jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119) at jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:104) at jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.java:579) at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:382) at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:608) at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:171) at jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:100) at javax.servlet.http.HttpServlet.service(HttpServlet.java:689) at javax.servlet.http.HttpServlet.service(HttpServlet.java:802) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869) at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664) at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527) at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684) at java.lang.Thread.run(Unknown Source) ** END NESTED EXCEPTION **
Muhammad Usman Iqbal
PhD Candidate
EE 413A, G17
School of Surveying and Spatial Information Systems
The University of New South Wales
Sydney NSW 2052, Australia
Phone: +61 2 9385 4206
Fax: +61 2 9313 7493
Email: m.iqbal@anonymised.com
Web: http://users.tpg.com.au/usmani/
