Hi ,
When I expand a metadata file to show all elements of the metadata and then >check box next to title > press "Actions of selection" > "Print to pdf"...a pdf file is created but it only contains the Abtract, title and Unique ID.
The individual metadata items are not printed to pdf.
Does anyone know why this is happening?
yours,
Rob
Hi Rob,
I think that's the default behaviour. If you want more than a metadata summary you will need to edit the metadata-fop.xsl file
James
-----Original Message-----
Sent: Wednesday, January 18, 2012 9:47 AM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Problem with metadata print to pdf
Hi ,
yours,
Rob
Keep Your Developer Skills Current with LearnDevNow!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-d2d
GeoNetwork-users mailing list
This message (and any attachments) is for the recipient only. NERC
is subject to the Freedom of Information Act 2000 and the contents
of this email and any reply you make may be disclosed by NERC unless
it is exempt from release under the Act. Any material supplied to
NERC may be stored in an electronic records management system.
