[GeoNetwork-users] problem with schema combobox
I tried to add new schema to GN in two ways.
Firstly I tried to change only iso19115 XML schema file. After that when I
try to add new XML file to database in forms the combobox of available
shcemas is empty and because of that I can't add it.
I tried also to add new schema by creating new folder in
..\geonetwork\web\xml\schemas and there is the same result.
I just want to add new xml file with validation. I don't want to use forms
and so on, I want just to add new file using "Batch import". Maybe I have to
make some changes in xml or xsl files ?? What kind of changes??
I'm using geonetwork 2.0.3.
Lukasz
View this message in context: http://www.nabble.com/problem-with-schema-combobox-tf3986485s18419.html#a11318920
Sent from the geonetwork-users mailing list archive at Nabble.com.
