[GeoNetwork-users] Problemas in Harverst in Geonetwork 2.10
Hello list, I have a problem doing harvest from within Geonetwork 2:10 at:
http://geoinfo.cnpm.embrapa.br/catalogue/csw?version=2.0.2&request=GetCapabilities&service=CSW
When making a getRecords at the same addresshttp://
geoinfo.cnpm.embrapa.br/catalogue/csw?request=GetRecords&service=CSW&version=2.0.2&resultType=results&outputSchema=http://www.isotc211.org/2005/gmd&typeNames=csw:Record&elementSetName=summary
.. Can receive all records in the answer, but while trying to run Harvest
Geonetwork pointing
revebo an error :
"Error: Raised exception when searching: Exception: the document is not
valid. Error: Element '{http://www.opengis.net/cat/csw/2.0.2\}Query',
attribute 'typeNames':
'gmd:MD_Metadata,csw:Record' is not a valid value of the atomic type
'xs:QName'."
I looked for the problem in the log of Tomcat, but found nothing.
Can anyone help?
Thanks
Davi de O. Custódio
I did not see an error as you reported. mine is 2.10.3. successfully
harvested on record as application service for it is a getCapabilities. A
while ago, I remember someone pointed out that the CSW should have a
'harvest' operation implemented for harvesting 'records'. 'getrecords' is
not sufficient for harvesting, per my limited knowledge on this topic.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problemas-in-Harverst-in-Geonetwork-2-10-tp5195219p5196495.html
