[GeoNetwork-users] Problems accesing external WMS
Hello all
We're registering metadata from WMS Services.
However, when we tray to visualize them in the Interactive Map, we get this
error (copy from the intermap.log ):
2009-04-29 12:03:36,092 DEBUG [jeeves.service] - -> parameters are :
<request>
  <clear>false</clear>
  <service>landform</service>
  <type>2</type>
  <url>http://geonetwork3.fao.org/ows/7386_landf&lt;/url&gt;
</request>
2009-04-29 12:03:36,092 DEBUG [intermap.wms] - Sending getCapabilities
request tohttp://geonetwork3.fao.org/ows/7386_landf
2009-04-29 12:03:37,217 ERROR [jeeves.service] - Exception when executing
service
2009-04-29 12:03:37,217 ERROR [jeeves.service] - (C) Exc :
java.net.ConnectException: Connection refused: connect
2009-04-29 12:03:37,217 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
  <message>Connection refused: connect</message>
  <class>ConnectException</class>
  <stack>
    <at class="java.net.PlainSocketImpl" file="???" line="-2"
method="socketConnect" />
    <at class="java.net.PlainSocketImpl" file="???" line="-1"
method="doConnect" />
method="connectToAddress" />
method="connect" />
    <at class="java.net.SocksSocketImpl" file="???" line="-1"
method="connect" />
    <at class="java.net.Socket" file="???" line="-1" method="connect" />
    <at class="sun.net.NetworkClient" file="???" line="-1"
    <at class="sun.net.www.http.HttpClient" file="???" line="-1"
method="openServer" />
  </stack>
  <request>
    <language>es</language>
    <service>map.addServices.embedded</service>
  </request>
</error>
Thank you in advance
Jesús de Diego
View this message in context: http://n2.nabble.com/Problems-accesing-external-WMS-tp2739798p2739798.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
I dont remenber so we were only testing. Any case, i seems a problem
with the proxy configuration.
Jesus de Diego
2010/6/18, vmag [via OSGeo.org]
<ml-node+5195416-1447015280-67519@anonymised.com>:
I have the same problem. Have you solved it?
______________________________________
View message @
http://osgeo-org.1803224.n2.nabble.com/Problems-accesing-external-WMS-tp2739798p5195416.html
To unsubscribe from Problems accesing external WMS, click
http://osgeo-org.1803224.n2.nabble.com/subscriptions/Unsubscribe.jtp?code=amVzZGlhbEBnbWFpbC5jb218MjczOTc5OHwtNjg5NTAyNzUz
Enviado desde mi dispositivo móvil
Jesús de Diego Alarcón
jesdial@anonymised.com
"La vida es linda, lo malo es que muchos confunden lindo con fácil."
Mafalda
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-accesing-external-WMS-tp2739798p5196759.html
You're right.
I searched trough intermap configuration files, and found one where i could
configure the proxy.
It's working now.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-accesing-external-WMS-tp2739798p5197005.html
