Dear colleagues, I am following Geonetwork instructions for INSPIRE configuration in Geonetwork 3.10.3:
In: Admin console/classification systems/tesaurus, when I select “use inspire registry” it appears the messages (translated from spanish to english):
- kind of registry not found, check the ur or
-Error when uploading the tesaurus. Unlnow format (must be in skos format). I attach images
After that, it’s not possible to continue, also it doesn’t appear Catalan language to check it. We need to select (Spanish, English and Catalan)
I suppose that the url its not correct one. These instructions are not updated per example the url for using “inspire validator”, cited at the beginning of the instructions, it’s the old one (http://inspire-sandbox.jrc.ec.europa.eu/etf-webapp ) fortunately Geoentwork 3.10.3 adds the actual one: https://inspire.ec.europa.eu/validator/
Can you help me? Thank you!
Regards. Margarita
(attachments)
