[GeoNetwork-users] Problems connecting to MySQL
Dear All,
I'm new to this geonetwork thing and I do have the same connection problem
to mySQL database
using GAST. I can Initiate database using Database>>Setup menu on GAST
as well as using command line, but I can't Import Sample Data nor
import/export Metadata.
Here is a capture from GAST window and resource setting on config.xml
I am using Geonetwork 2.10 on Windows XP professional
Does anyone know how to solve this?
Thank's in advance
Inus
attachment :
<!------------------trace from GAST
C:\Program Files\geonetwork\bin>cd ..\gast
C:\Program Files\geonetwork\gast>java -jar gast.jar
37516 [Thread-6] INFO httpclient.HttpMethodDirector - I/O exception
(java.net.ConnectException) caught when processing request: Connection
refused: connect
37516 [Thread-6] INFO httpclient.HttpMethodDirector - Retrying request
refused: connect
refused: connect
requestjava.net.ConnectException: Connection refused: connect
        at java.net.PlainSocketImpl.socketConnect(Native Method)
        at java.net.PlainSocketImpl.doConnect(Unknown Source)
        at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
        at java.net.PlainSocketImpl.connect(Unknown Source)
        at java.net.SocksSocketImpl.connect(Unknown Source)
        at java.net.Socket.connect(Unknown Source)
        at java.net.Socket.<init>(Unknown Source)
        at
org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultProtocolSocketFactory.java:79)
        at
org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultProtocolSocketFactory.java:121)
        at
org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:706)
        at
org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:386)
        at
org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:170)
        at
org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:396)
        at
org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:324)
        at jeeves.utils.XmlRequest.doExecute(XmlRequest.java:315)
        at jeeves.utils.XmlRequest.send(XmlRequest.java:278)
        at
org.fao.gast.gui.panels.database.sample.Worker.send(Worker.java:146)
        at
org.fao.gast.gui.panels.database.sample.Worker.executeJob(Worker.java:110)
        at
org.fao.gast.gui.panels.database.sample.Worker.run(Worker.java:73)
        at java.lang.Thread.run(Unknown Source)
<!-- This is the resource setting in "C:\Program
Files\geonetwork\web\geonetwork\WEB-INF\config.xml" -->
  <resources>
    <!-- mysql
    <!-- all CAPS belong to my setting - - - - - - - - - - - - - - - - - - - -
    <resource enabled="true">
      <name>main-db</name>
      <provider>jeeves.resources.dbms.DbmsPool</provider>
      <config>
        <user>MY_SQL_USER</user>
        <password>MY_SQL_PASSWORD</password>
        <driver>com.mysql.jdbc.Driver</driver>
        <url>jdbc:mysql://MY_HOSTNAME:MY_SQL_PORT/MY_DATABASE_NAME</url>
        <poolSize>10</poolSize>
      </config>
    </resource>
  </resources>
Jason Pickering wrote:
Hi Everyone,
I have some problems connecting to a MySQL database with Geoserver 2.10. I
am running Geoserver on Ubuntu, under Tomcat 6.0.14. I get the following
nasty stack trace when I try and connect to a mysql database on my local
server. I can access the database through the mysql command line utility,
as well as initiating the database tables with GAST. However, I cannot
connect to the database with GAST and insert the sample metadata. I
suspect the problems are related, but I am not sure.
Here is the stack trace as an attachment. This issue affects both Jetty
and Tomcat, but I have included the stack trace from Jetty only.
Thanks for any help.
Best regards,
Jason
2008-01-11 11:50:14 | Total memory is : 504896 Kb
2008-01-11 11:50:14 | Startup time is : 0 (secs)
2008-01-11 11:50:14 | === System working
11:50:14.487 INFO [main]
org.mortbay.util.Container.start(Container.java:74) >11> Started
WebApplicationContext[/intermap,intermap]
11:50:14.688 INFO [main]
org.mortbay.util.Container.start(Container.java:74) >15> Started
org.mortbay.jetty.servlet.WebApplicationHandler@anonymised.com
2008-01-11 11:50:14,793 INFO [jeeves.engine] - === Starting system
2008-01-11 11:50:14,793 INFO [jeeves.engine] - Java version :
1.6.0_03-b05
2008-01-11 11:50:14,794 INFO [jeeves.engine] - Java vendor : Sun
Microsystems Inc.
2008-01-11 11:50:14,880 INFO [jeeves.engine] - XSLT factory :
org.apache.xalan.transformer.TransformerIdentityImpl
2008-01-11 11:50:14,881 INFO [jeeves.engine] - Path :
/home/pickeringj/geonetwork_210/web/geonetwork/
2008-01-11 11:50:14,881 INFO [jeeves.engine] - BaseURL : geonetwork
2008-01-11 11:50:14,881 INFO [jeeves.engine] - Loading :
/home/pickeringj/geonetwork_210/web/geonetwork/WEB-INF/config.xml
2008-01-11 11:50:15,005 INFO [jeeves.engine] - Initializing general
configuration...
2008-01-11 11:50:15,008 INFO [jeeves.engine] - Initializing defaults...
2008-01-11 11:50:15,008 INFO [jeeves.engine] - Default local is :true
2008-01-11 11:50:15,016 INFO [jeeves.engine] - Initializing resources...
2008-01-11 11:50:15,021 INFO [jeeves.engine] - Adding resource :
main-db
2008-01-11 11:50:15,160 ERROR [jeeves.engine] - Raised exception while
initializing resource. Skipped.
2008-01-11 11:50:15,160 ERROR [jeeves.engine] - Resource : main-db
2008-01-11 11:50:15,161 ERROR [jeeves.engine] - Provider :
2008-01-11 11:50:15,161 ERROR [jeeves.engine] - Exception :
com.mysql.jdbc.CommunicationsException: Communications link failure due to
underlying exception:
** BEGIN NESTED EXCEPTION **
java.net.UnknownHostException
MESSAGE: $WEBSERVER_HOST
STACKTRACE:
java.net.UnknownHostException: $WEBSERVER_HOST
        at java.net.Inet4AddressImpl.lookupAllHostAddr(Native Method)
        at java.net.InetAddress$1.lookupAllHostAddr(InetAddress.java:849)
        at
java.net.InetAddress.getAddressFromNameService(InetAddress.java:1200)
        at java.net.InetAddress.getAllByName0(InetAddress.java:1153)
        at java.net.InetAddress.getAllByName(InetAddress.java:1083)
        at java.net.InetAddress.getAllByName(InetAddress.java:1019)
        at
com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:246)
        at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:271)
        at com.mysql.jdbc.Connection.createNewIO(Connection.java:2744)
        at com.mysql.jdbc.Connection.<init>(Connection.java:1553)
        at
com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:285)
        at java.sql.DriverManager.getConnection(DriverManager.java:582)
        at java.sql.DriverManager.getConnection(DriverManager.java:185)
        at jeeves.resources.dbms.Dbms.connect(Dbms.java:86)
        at jeeves.resources.dbms.DbmsPool.init(DbmsPool.java:82)
        at
jeeves.server.resources.ProviderManager.register(ProviderManager.java:54)
        at jeeves.server.JeevesEngine.initResources(JeevesEngine.java:361)
        at
jeeves.server.JeevesEngine.loadConfigFile(JeevesEngine.java:214)
        at jeeves.server.JeevesEngine.init(JeevesEngine.java:131)
        at
jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:65)
        at javax.servlet.GenericServlet.init(GenericServlet.java:168)
        at
org.mortbay.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:383)
        at
org.mortbay.jetty.servlet.ServletHolder.start(ServletHolder.java:243)
        at
org.mortbay.jetty.servlet.ServletHandler.initializeServlets(ServletHandler.java:446)
        at
org.mortbay.jetty.servlet.WebApplicationHandler.initializeServlets(WebApplicationHandler.java:321)
        at
org.mortbay.jetty.servlet.WebApplicationContext.doStart(WebApplicationContext.java:511)
        at org.mortbay.util.Container.start(Container.java:72)
        at org.mortbay.http.HttpServer.doStart(HttpServer.java:753)
        at org.mortbay.jetty.Server.main(Server.java:439)
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at org.mortbay.start.Main.invokeMain(Main.java:151)
        at org.mortbay.start.Main.start(Main.java:476)
        at org.mortbay.start.Main.main(Main.java:94)
** END NESTED EXCEPTION **
Last packet sent to the server was 1 ms ago.
2008-01-11 11:50:15,161 ERROR [jeeves.engine] - Message :
Communications link failure due to underlying exception:
STACKTRACE:
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
2008-01-11 11:50:15,162 ERROR [jeeves.engine] - Stack :
STACKTRACE:
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at com.mysql.jdbc.Connection.createNewIO(Connection.java:2820)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
2008-01-11 11:50:15,162 INFO [jeeves.engine] - Initializing services...
2008-01-11 11:50:15,162 INFO [jeeves.engine] - Adding service :
main.home
2008-01-11 11:50:15,169 INFO [jeeves.engine] - Adding service :
main.search
2008-01-11 11:50:15,170 INFO [jeeves.engine] - Adding service :
main.search.embedded
2008-01-11 11:50:15,171 INFO [jeeves.engine] - Adding service :
main.present.embedded
main.searchform.advanced.embedded
2008-01-11 11:50:15,172 INFO [jeeves.engine] - Adding service :
main.searchform.simple.embedded
main.present
remote.show
2008-01-11 11:50:15,174 INFO [jeeves.engine] - Adding service :
feedback
2008-01-11 11:50:15,174 INFO [jeeves.engine] - Adding service : links
2008-01-11 11:50:15,174 INFO [jeeves.engine] - Adding service : about
xml.region.get
2008-01-11 11:50:15,175 INFO [jeeves.engine] - Adding service :
feedback.insert
2008-01-11 11:50:15,176 INFO [jeeves.engine] - Adding service :
util.ping
2008-01-11 11:50:15,177 INFO [jeeves.engine] - Adding service :
util.import
2008-01-11 11:50:15,179 INFO [jeeves.engine] - Adding service :
user.list
2008-01-11 11:50:15,180 INFO [jeeves.engine] - Adding service :
user.get
2008-01-11 11:50:15,181 INFO [jeeves.engine] - Adding service :
user.update
2008-01-11 11:50:15,182 INFO [jeeves.engine] - Adding service :
user.remove
2008-01-11 11:50:15,183 INFO [jeeves.engine] - Adding service :
user.pwedit
user.pwupdate
2008-01-11 11:50:15,184 INFO [jeeves.engine] - Adding service :
user.infoedit
2008-01-11 11:50:15,186 INFO [jeeves.engine] - Adding service :
user.infoupdate
2008-01-11 11:50:15,187 INFO [jeeves.engine] - Adding service :
group.list
2008-01-11 11:50:15,188 INFO [jeeves.engine] - Adding service :
group.get
2008-01-11 11:50:15,189 INFO [jeeves.engine] - Adding service :
group.update
group.remove
2008-01-11 11:50:15,190 INFO [jeeves.engine] - Adding service :
xml.group.update
2008-01-11 11:50:15,191 INFO [jeeves.engine] - Adding service :
category.list
category.get
2008-01-11 11:50:15,192 INFO [jeeves.engine] - Adding service :
category.update
2008-01-11 11:50:15,193 INFO [jeeves.engine] - Adding service :
category.remove
2008-01-11 11:50:15,194 INFO [jeeves.engine] - Adding service :
xml.category.update
2008-01-11 11:50:15,195 INFO [jeeves.engine] - Adding service :
user.login
2008-01-11 11:50:15,197 INFO [jeeves.engine] - Adding service :
user.logout
2008-01-11 11:50:15,197 INFO [jeeves.engine] - Adding service : admin
2008-01-11 11:50:15,198 INFO [jeeves.engine] - Adding service : config
xml.config.get
2008-01-11 11:50:15,199 INFO [jeeves.engine] - Adding service :
xml.config.set
2008-01-11 11:50:15,201 INFO [jeeves.engine] - Adding service :
localization
2008-01-11 11:50:15,202 INFO [jeeves.engine] - Adding service :
xml.operation.update
2008-01-11 11:50:15,203 INFO [jeeves.engine] - Adding service :
xml.region.update
2008-01-11 11:50:15,204 INFO [jeeves.engine] - Adding service : help
xml.schema.info
2008-01-11 11:50:15,206 INFO [jeeves.engine] - Adding service :
file.disclaimer
file.download
graphover.show
resources.get
2008-01-11 11:50:15,208 INFO [jeeves.engine] - Adding service :
resources.upload
2008-01-11 11:50:15,210 INFO [jeeves.engine] - Adding service :
resources.del
2008-01-11 11:50:15,211 INFO [jeeves.engine] - Adding service :
xml.user.login
xml.user.logout
2008-01-11 11:50:15,212 INFO [jeeves.engine] - Adding service :
xml.search
2008-01-11 11:50:15,213 INFO [jeeves.engine] - Adding service :
xml.metadata.get
2008-01-11 11:50:15,214 INFO [jeeves.engine] - Adding service :
xml.info
2008-01-11 11:50:15,219 INFO [jeeves.engine] - Adding service :
xml.forward
2008-01-11 11:50:15,221 INFO [jeeves.engine] - Adding service :
xml.user.list
xml.group.list
xml.metadata.insert
2008-01-11 11:50:15,222 INFO [jeeves.engine] - Adding service :
xml.metadata.delete
2008-01-11 11:50:15,224 INFO [jeeves.engine] - Adding service : csw
2008-01-11 11:50:15,240 INFO [jeeves.engine] - Adding service :
rss.latest
rss.search
2008-01-11 11:50:15,241 INFO [jeeves.engine] - Adding service :
rss.present
mef.import
2008-01-11 11:50:15,242 INFO [jeeves.engine] - Adding service :
mef.export
xml.relation.get
2008-01-11 11:50:15,243 INFO [jeeves.engine] - Adding service :
keywords.getselected
2008-01-11 11:50:15,244 INFO [jeeves.engine] - Adding service :
keywords.sort
2008-01-11 11:50:15,245 INFO [jeeves.engine] - Adding service :
keywords.select
2008-01-11 11:50:15,246 INFO [jeeves.engine] - Adding service :
keywords.search
2008-01-11 11:50:15,247 INFO [jeeves.engine] - Adding service :
xml.search.keywords
2008-01-11 11:50:15,257 INFO [jeeves.engine] - Adding service :
xml.search.keywordlink
2008-01-11 11:50:15,258 INFO [jeeves.engine] - Adding service :
keywords.editsearch
2008-01-11 11:50:15,260 INFO [jeeves.engine] - Adding service :
thesaurus.admin
2008-01-11 11:50:15,261 INFO [jeeves.engine] - Adding service :
thesaurus.upload
2008-01-11 11:50:15,262 INFO [jeeves.engine] - Adding service :
thesaurus.download
2008-01-11 11:50:15,263 INFO [jeeves.engine] - Adding service :
thesaurus.delete
2008-01-11 11:50:15,264 INFO [jeeves.engine] - Adding service :
thesaurus.view
thesaurus.add
2008-01-11 11:50:15,265 INFO [jeeves.engine] - Adding service :
thesaurus.edit
thesaurus.update
thesaurus.editelement
2008-01-11 11:50:15,269 INFO [jeeves.engine] - Adding service :
thesaurus.addelement
2008-01-11 11:50:15,270 INFO [jeeves.engine] - Adding service :
thesaurus.updateelement
thesaurus.deleteelement
2008-01-11 11:50:15,271 INFO [jeeves.engine] - Initializing schedules...
2008-01-11 11:50:15,271 INFO [jeeves.engine] - Loading :
/home/pickeringj/geonetwork_210/web/geonetwork/WEB-INF/config-metadata.xml
2008-01-11 11:50:15,286 INFO [jeeves.engine] - Initializing services...
2008-01-11 11:50:15,286 INFO [jeeves.engine] - Adding service :
metadata.insert
2008-01-11 11:50:15,287 INFO [jeeves.engine] - Adding service :
metadata.show
2008-01-11 11:50:15,288 INFO [jeeves.engine] - Adding service :
metadata.show.embedded
metadata.edit
2008-01-11 11:50:15,290 INFO [jeeves.engine] - Adding service :
metadata.elem.add
2008-01-11 11:50:15,291 INFO [jeeves.engine] - Adding service :
metadata.elem.delete
2008-01-11 11:50:15,292 INFO [jeeves.engine] - Adding service :
metadata.update
2008-01-11 11:50:15,293 INFO [jeeves.engine] - Adding service :
metadata.update.finish
metadata.update.validate
metadata.elem.down
2008-01-11 11:50:15,294 INFO [jeeves.engine] - Adding service :
metadata.elem.up
metadata.attr.add
2008-01-11 11:50:15,295 INFO [jeeves.engine] - Adding service :
metadata.attr.delete
2008-01-11 11:50:15,296 INFO [jeeves.engine] - Adding service :
metadata.delete
metadata.create.form
2008-01-11 11:50:15,298 INFO [jeeves.engine] - Adding service :
metadata.duplicate.form
metadata.create
2008-01-11 11:50:15,299 INFO [jeeves.engine] - Adding service :
metadata.admin.form
2008-01-11 11:50:15,300 INFO [jeeves.engine] - Adding service :
metadata.admin
2008-01-11 11:50:15,301 INFO [jeeves.engine] - Adding service :
metadata.category.form
2008-01-11 11:50:15,302 INFO [jeeves.engine] - Adding service :
metadata.category
metadata.xmlinsert.form
2008-01-11 11:50:15,303 INFO [jeeves.engine] - Adding service :
metadata.batchimport.form
metadata.searchunused.form
2008-01-11 11:50:15,304 INFO [jeeves.engine] - Adding service :
metadata.thumbnail.form
2008-01-11 11:50:15,305 INFO [jeeves.engine] - Adding service :
metadata.thumbnail.set
2008-01-11 11:50:15,307 INFO [jeeves.engine] - Adding service :
metadata.thumbnail.unset
2008-01-11 11:50:15,308 INFO [jeeves.engine] - Adding service :
transfer.ownership
xml.ownership.editors
2008-01-11 11:50:15,309 INFO [jeeves.engine] - Adding service :
xml.ownership.groups
2008-01-11 11:50:15,310 INFO [jeeves.engine] - Adding service :
xml.ownership.transfer
2008-01-11 11:50:15,311 INFO [jeeves.engine] - Loading :
/home/pickeringj/geonetwork_210/web/geonetwork/WEB-INF/config-harvesting.xml
2008-01-11 11:50:15,315 INFO [jeeves.engine] - Initializing services...
2008-01-11 11:50:15,315 INFO [jeeves.engine] - Adding service :
harvesting
xml.harvesting.get
2008-01-11 11:50:15,316 INFO [jeeves.engine] - Adding service :
xml.harvesting.add
2008-01-11 11:50:15,317 INFO [jeeves.engine] - Adding service :
xml.harvesting.update
xml.harvesting.remove
2008-01-11 11:50:15,319 INFO [jeeves.engine] - Adding service :
xml.harvesting.start
xml.harvesting.stop
2008-01-11 11:50:15,320 INFO [jeeves.engine] - Adding service :
xml.harvesting.run
2008-01-11 11:50:15,321 INFO [jeeves.engine] - Adding service :
xml.harvesting.info
2008-01-11 11:50:15,322 INFO [jeeves.engine] - Loading :
/home/pickeringj/geonetwork_210/web/geonetwork/WEB-INF/config-portal.xml
2008-01-11 11:50:15,345 INFO [jeeves.engine] - Initializing services...
2008-01-11 11:50:15,345 INFO [jeeves.engine] - Adding service :
portal.search
2008-01-11 11:50:15,365 INFO [jeeves.engine] - Adding service :
portal.opensearch
2008-01-11 11:50:15,366 INFO [jeeves.engine] - Adding service :
portal.search.keywords
portal.present
portal.search.present
2008-01-11 11:50:15,367 INFO [jeeves.engine] - Adding service :
portal.full
portal.latest.updated
portal.featured
portal.categories
2008-01-11 11:50:15,367 INFO [jeeves.engine] - Loading :
/home/pickeringj/geonetwork_210/web/geonetwork/WEB-INF/config-export.xml
2008-01-11 11:50:15,371 INFO [jeeves.engine] - Initializing services...
2008-01-11 11:50:15,371 INFO [jeeves.engine] - Adding service : dc.xml
fgdc.xml
iso19115to19139.xml
2008-01-11 11:50:15,372 INFO [jeeves.engine] - Adding service :
iso19139.xml
iso_arccatalog8.xml
2008-01-11 11:50:15,372 INFO [jeeves.engine] - Initializing profiles...
2008-01-11 11:50:15,382 INFO [jeeves.engine] - Found handler :
org.fao.geonet.Geonetwork
2008-01-11 11:50:15,386 INFO [jeeves.engine] - --- Starting handler
2008-01-11 11:50:15,386 INFO [jeeves.apphand] - Initializing
geonetwork...
2008-01-11 11:50:15,386 ERROR [jeeves.engine] - Raised exception while
starting appl handler. Skipped.
2008-01-11 11:50:15,386 ERROR [jeeves.engine] - Handler :
2008-01-11 11:50:15,386 ERROR [jeeves.engine] - Exception :
java.lang.NullPointerException
2008-01-11 11:50:15,387 ERROR [jeeves.engine] - Message : null
2008-01-11 11:50:15,387 ERROR [jeeves.engine] - Stack :
        at
jeeves.server.resources.ResourceManager.open(ResourceManager.java:68)
        at org.fao.geonet.Geonetwork.start(Geonetwork.java:85)
        at
jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:409)
        at jeeves.server.JeevesEngine.init(JeevesEngine.java:140)
        at
        at
        at
        at
        at
        at
        at
        at
2008-01-11 11:50:15,387 INFO [jeeves.engine] - Starting schedule
manager...
2008-01-11 11:50:15,387 INFO [jeeves.engine] - Memory used is : -4819 Kb
2008-01-11 11:50:15,388 INFO [jeeves.engine] - Total memory is : 504896
Kb
2008-01-11 11:50:15,388 INFO [jeeves.engine] - Startup time is : 0 (secs)
2008-01-11 11:50:15,388 INFO [jeeves.engine] - === System working
11:50:15.435 INFO [main]
WebApplicationContext[/geonetwork,geonetwork]
11:50:15.718 INFO [main]
1716 [main] INFO org.springframework.web.context.ContextLoader - Root
WebApplicationContext: initialization started
11:50:15.745 INFO [main]
org.mortbay.jetty.servlet.ServletHandler$Context.log(ServletHandler.java:1134)
>15> Loading Spring root WebApplicationContext
1781 [main] INFO
org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading
XML bean definitions from URL
[jar:file:/home/pickeringj/geonetwork_210/web/geoserver/WEB-INF/lib/wfs-1.5.3.jar!/applicationContext.xml]
1870 [main] INFO
[jar:file:/home/pickeringj/geonetwork_210/web/geoserver/WEB-INF/lib/validation-1.5.3.jar!/applicationContext.xml]
1891 [main] INFO
[jar:file:/home/pickeringj/geonetwork_210/web/geoserver/WEB-INF/lib/data-1.5.3.jar!/applicationContext.xml]
1926 [main] INFO
[jar:file:/home/pickeringj/geonetwork_210/web/geoserver/WEB-INF/lib/main-1.5.3.jar!/applicationContext.xml]
2038 [main] INFO
[jar:file:/home/pickeringj/geonetwork_210/web/geoserver/WEB-INF/lib/wms-1.5.3.jar!/applicationContext.xml]
2134 [main] INFO
[jar:file:/home/pickeringj/geonetwork_210/web/geoserver/WEB-INF/lib/wcs-1.5.3.jar!/applicationContext.xml]
2157 [main] INFO
[file:/home/pickeringj/geonetwork_210/web/geoserver/WEB-INF/classes/applicationContext.xml]
2174 [main] INFO
org.springframework.web.context.support.XmlWebApplicationContext - Bean
factory for application context [Root WebApplicationContext]:
org.springframework.beans.factory.support.DefaultListableBeanFactory
defining beans
[wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,validation,validationConfig,validationRegisterar,validationConfigRegisterar,catalog,serviceFinder,config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsGetCapabilitiesLegacy,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,wmsReflect,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapProducerFactory,TiffMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProducerFactory,OpenLayersMapProducerFactory,GeoRSSMapProducerFactory,wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,applicationState,applicationStateRegisterar];
root of BeanFactory hierarchy
2182 [main] INFO
org.springframework.web.context.support.XmlWebApplicationContext - 72
beans defined in application context [Root WebApplicationContext]
2204 [main] INFO org.springframework.core.CollectionFactory - Commons
Collections 3.x available
2210 [main] INFO
org.springframework.web.context.support.XmlWebApplicationContext - Unable
to locate MessageSource with name 'messageSource': using default
[org.springframework.context.support.DelegatingMessageSource@anonymised.com]
2214 [main] INFO
to locate ApplicationEventMulticaster with name
'applicationEventMulticaster': using default
[org.springframework.context.event.SimpleApplicationEventMulticaster@anonymised.com41...]
2218 [main] INFO
org.springframework.ui.context.support.UiApplicationContextUtils - Unable
to locate ThemeSource with name 'themeSource': using default
[org.springframework.ui.context.support.ResourceBundleThemeSource@anonymised.com..]
2226 [main] INFO
org.springframework.beans.factory.support.DefaultListableBeanFactory -
Pre-instantiating singletons in factory
[org.springframework.beans.factory.support.DefaultListableBeanFactory
defining beans
root of BeanFactory hierarchy]
- GEOSERVER_DATA_DIR: /home/pickeringj/geonetwork_210/web/geoserver/data
4568 [main] INFO org.springframework.web.context.ContextLoader - Using
context class
[org.springframework.web.context.support.XmlWebApplicationContext] for
4569 [main] INFO org.springframework.web.context.ContextLoader - Root
WebApplicationContext: initialization completed in 2854 ms
5186 [main] INFO org.apache.struts.tiles.TilesPlugin - Tiles definition
factory loaded for module ''.
5336 [main] INFO org.apache.struts.validator.ValidatorPlugIn - Loading
validation rules file from '/WEB-INF/validator-rules.xml'
validation rules file from '/WEB-INF/validation.xml'
5450 [main] INFO org.springframework.web.struts.ContextLoaderPlugIn -
ContextLoaderPlugIn for Struts ActionServlet 'action, module '':
11:50:19.480 INFO [main]
>22> Initializing WebApplicationContext for Struts ActionServlet 'action',
module ''
5452 [main] INFO
XML bean definitions from ServletContext resource
[/WEB-INF/action-servlet.xml]
5465 [main] INFO
factory for application context [WebApplicationContext for namespace
'action-servlet']:
defining beans [/admin/loginSubmit]; parent:
defining beans
5470 [main] INFO
org.springframework.web.context.support.XmlWebApplicationContext - 1 beans
defined in application context [WebApplicationContext for namespace
'action-servlet']
5470 [main] INFO
5471 [main] INFO
[org.springframework.context.event.SimpleApplicationEventMulticaster@anonymised.com44...]
5471 [main] INFO
[org.springframework.ui.context.support.DelegatingThemeSource@anonymised.com]
5471 [main] INFO
defining beans
5476 [main] INFO org.springframework.web.struts.ContextLoaderPlugIn -
Using context class
'org.springframework.web.context.support.XmlWebApplicationContext' for
servlet 'action'
5477 [main] INFO org.springframework.web.struts.ContextLoaderPlugIn -
ContextLoaderPlugIn for Struts ActionServlet 'action', module '':
initialization completed in 26 ms
11:50:19.509 INFO [main]
WebApplicationContext[/geoserver,GeoServer]
11:50:19.556 INFO [main]
org.mortbay.http.SocketListener.start(SocketListener.java:204) >11>
Started SocketListener on 0.0.0.0:8080
org.mortbay.util.Container.start(Container.java:74) >09> Started
org.mortbay.jetty.Server@anonymised.com
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
GeoNetwork-users mailing list
View this message in context: http://www.nabble.com/Problems-connecting-to-MySQL-tp14754129s18419p15155559.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
