Im installing geonetwork in Jboss, after deploying the application it doesnt work at all. The log file is showing me this:
2008-08-14 11:58:17,906 INFO [jeeves.request] - ==========================================================
2008-08-14 11:58:17,906 INFO [jeeves.request] - HTML Request (from 127.0.0.1) : /geonetwork/srv/en/main.home
2008-08-14 11:58:17,906 DEBUG [jeeves.request] - Method : GET
2008-08-14 11:58:17,906 DEBUG [jeeves.request] - Content type : null
2008-08-14 11:58:17,906 DEBUG [jeeves.request] - Accept : image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, application/x-silverlight, application/x-silverlight-2-b2, */*
2008-08-14 11:58:17,906 INFO [jeeves.service] - Dispatching : main.home
2008-08-14 11:58:17,906 DEBUG [jeeves.service] - -> no input parameters
2008-08-14 11:58:17,906 INFO [jeeves.service] - -> dispatching to output for : main.home
2008-08-14 11:58:17,984 ERROR [jeeves.service] - Exception executing gui service : java.lang.NullPointerException
2008-08-14 11:58:17,984 ERROR [jeeves.service] - (C) Stack trace is :
at org.fao.geonet.guiservices.util.Env.exec(Env.java:53)
at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75)
at jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119)
at jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:103)
at jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.java:588)
at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:382)
at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:616)
at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:163)
at jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:88)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:697)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:175)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:74)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.jboss.web.tomcat.tc5.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:156)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at org.apache.tomcat.util.net.MasterSlaveWorkerThread.run(MasterSlaveWorkerThread.java:112)
at java.lang.Thread.run(Thread.java:619)
2008-08-14 11:58:17,984 INFO [jeeves.webapp.main.home] - Returning search data
at org.fao.geonet.guiservices.keywords.Get.exec(Get.java:55)
at jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:104)
2008-08-14 11:58:18,000 ERROR [jeeves.service] - Exception executing gui service : java.lang.NullPointerException
2008-08-14 11:58:18,000 ERROR [jeeves.service] - (C) Stack trace is :
at org.fao.geonet.guiservices.util.Sources.exec(Sources.java:50)
at org.fao.geonet.guiservices.metadata.GetLatestUpdated.exec(GetLatestUpdated.java:76)
at org.fao.geonet.guiservices.metadata.GetRandom.exec(GetRandom.java:82)
2008-08-14 11:58:18,000 INFO [jeeves.service] - -> transforming with stylesheet : D:\Jboss\jboss-4.0.5.GA\server\default\.\deploy\geonetwork.war\/xsl/main-page.xsl
2008-08-14 11:58:18,734 INFO [jeeves.service] - -> end transformation for : main.home
2008-08-14 11:58:18,734 INFO [jeeves.service] - -> output ended for : main.home
2008-08-14 11:58:18,734 INFO [jeeves.service] - -> dispatch ended for : main.home
2008-08-14 11:58:19,828 INFO [jeeves.request] - ==========================================================
2008-08-14 11:58:19,828 INFO [jeeves.request] - HTML Request (from 127.0.0.1) : /geonetwork/srv/en/portal.opensearch
2008-08-14 11:58:19,828 DEBUG [jeeves.request] - Method : GET
2008-08-14 11:58:19,828 DEBUG [jeeves.request] - Content type : null
2008-08-14 11:58:19,828 DEBUG [jeeves.request] - Accept : */*
2008-08-14 11:58:19,828 INFO [jeeves.service] - Dispatching : portal.opensearch
2008-08-14 11:58:19,828 DEBUG [jeeves.service] - -> no input parameters
2008-08-14 11:58:19,843 ERROR [jeeves.service] - Exception when executing service
2008-08-14 11:58:19,843 ERROR [jeeves.service] - (C) Exc : java.lang.NullPointerException
2008-08-14 11:58:19,843 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
<message />
<class>NullPointerException</class>
<stack>
<at class="org.fao.geonet.services.config.Get" file="Get.java" line="57" method="exec" />
<at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="238" method="execService" />
<at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="141" method="execServices" />
<at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="376" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java" line="616" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="163" method="execute" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="88" method="doGet" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="697" method="service" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="810" method="service" />
<at class="org.apache.catalina.core.ApplicationFilterChain" file="ApplicationFilterChain.java" line="252" method="internalDoFilter" />
</stack>
<request>
<language>en</language>
<service>portal.opensearch</service>
</request>
</error>
2008-08-14 11:58:19,843 INFO [jeeves.service] - -> dispatching to error for : portal.opensearch
2008-08-14 11:58:19,890 ERROR [jeeves.service] - Exception executing gui service : java.lang.NullPointerException
2008-08-14 11:58:19,890 ERROR [jeeves.service] - (C) Stack trace is :
at jeeves.server.dispatchers.ServiceManager.dispatchError(ServiceManager.java:672)
at jeeves.server.dispatchers.ServiceManager.handleError(ServiceManager.java:464)
at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:409)
2008-08-14 11:58:19,906 INFO [jeeves.service] - -> transforming with stylesheet : D:\Jboss\jboss-4.0.5.GA\server\default\.\deploy\geonetwork.war\/xsl/error.xsl
2008-08-14 11:58:20,046 INFO [jeeves.service] - -> end error transformation for : portal.opensearch
2008-08-14 11:58:20,046 INFO [jeeves.service] - -> error ended for : portal.opensearch
2008-08-14 11:58:20,062 INFO [jeeves.request] - ==========================================================
2008-08-14 11:58:20,062 INFO [jeeves.request] - HTML Request (from 127.0.0.1) : /geonetwork/srv/en/null
2008-08-14 11:58:20,062 DEBUG [jeeves.request] - Method : GET
2008-08-14 11:58:20,062 DEBUG [jeeves.request] - Content type : null
2008-08-14 11:58:20,062 DEBUG [jeeves.request] - Accept : */*
2008-08-14 11:58:20,062 INFO [jeeves.service] - Dispatching : null
2008-08-14 11:58:20,062 DEBUG [jeeves.service] - -> no input parameters
2008-08-14 11:58:20,062 ERROR [jeeves.service] - Service not found : null
2008-08-14 11:58:20,062 DEBUG [jeeves.service] - Raised exception while executing service
<error id="service-not-found">
<message>Service not found</message>
<class>ServiceNotFoundEx</class>
<stack>
<at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="342" method="dispatch" />
<at class="org.apache.catalina.core.ApplicationFilterChain" file="ApplicationFilterChain.java" line="173" method="doFilter" />
<at class="org.jboss.web.tomcat.filters.ReplyHeaderFilter" file="ReplyHeaderFilter.java" line="96" method="doFilter" />
<at class="org.apache.catalina.core.ApplicationFilterChain" file="ApplicationFilterChain.java" line="202" method="internalDoFilter" />
</stack>
<object>null</object>
<request>
<service>null</service>
</request>
</error>
2008-08-14 11:58:20,062 INFO [jeeves.service] - -> dispatching to error for : null
2008-08-14 11:58:20,109 ERROR [jeeves.service] - Exception executing gui service : java.lang.NullPointerException
2008-08-14 11:58:20,109 ERROR [jeeves.service] - (C) Stack trace is :
2008-08-14 11:58:20,109 INFO [jeeves.service] - -> transforming with stylesheet : D:\Jboss\jboss-4.0.5.GA\server\default\.\deploy\geonetwork.war\/xsl/error.xsl
2008-08-14 11:58:20,187 INFO [jeeves.service] - -> end error transformation for : null
2008-08-14 11:58:20,187 INFO [jeeves.service] - -> error ended for : null
2008-08-14 11:58:31,921 INFO [jeeves.request] - ==========================================================
2008-08-14 11:58:31,921 INFO [jeeves.request] - HTML Request (from 127.0.0.1) : /geonetwork/srv/en/user.login
2008-08-14 11:58:31,921 DEBUG [jeeves.request] - Method : POST
2008-08-14 11:58:31,921 DEBUG [jeeves.request] - Content type : application/x-www-form-urlencoded
2008-08-14 11:58:31,921 DEBUG [jeeves.request] - Accept : image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, application/x-silverlight, application/x-silverlight-2-b2, */*
2008-08-14 11:58:31,921 INFO [jeeves.service] - Dispatching : user.login
2008-08-14 11:58:31,921 DEBUG [jeeves.service] - -> parameters are :
<request>
<password>admin</password>
<username>admin</username>
</request>
2008-08-14 11:58:31,921 ERROR [jeeves.service] - Exception when executing service
2008-08-14 11:58:31,921 ERROR [jeeves.service] - (C) Exc : java.lang.NullPointerException
2008-08-14 11:58:31,921 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
<message />
<stack>
<at class="org.fao.geonet.services.login.Login" file="Login.java" line="67" method="exec" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="98" method="doPost" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="717" method="service" />
</stack>
<request>
<service>user.login</service>
</request>
</error>
2008-08-14 11:58:31,921 INFO [jeeves.service] - -> dispatching to error for : user.login
2008-08-14 11:58:31,968 ERROR [jeeves.service] - Exception executing gui service : java.lang.NullPointerException
2008-08-14 11:58:31,968 ERROR [jeeves.service] - (C) Stack trace is :
at jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:98)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
2008-08-14 11:58:31,968 INFO [jeeves.service] - -> transforming with stylesheet : D:\Jboss\jboss-4.0.5.GA\server\default\.\deploy\geonetwork.war\/xsl/error.xsl
2008-08-14 11:58:32,046 INFO [jeeves.service] - -> end error transformation for : user.login
2008-08-14 11:58:32,046 INFO [jeeves.service] - -> error ended for : user.login
2008-08-14 11:58:32,203 INFO [jeeves.request] - ==========================================================
2008-08-14 11:58:32,203 INFO [jeeves.request] - HTML Request (from 127.0.0.1) : /geonetwork/srv/en/portal.opensearch
2008-08-14 11:58:32,203 DEBUG [jeeves.request] - Method : GET
2008-08-14 11:58:32,203 DEBUG [jeeves.request] - Content type : null
2008-08-14 11:58:32,203 DEBUG [jeeves.request] - Accept : */*
2008-08-14 11:58:32,203 INFO [jeeves.service] - Dispatching : portal.opensearch
2008-08-14 11:58:32,203 DEBUG [jeeves.service] - -> no input parameters
2008-08-14 11:58:32,203 ERROR [jeeves.service] - Exception when executing service
2008-08-14 11:58:32,203 ERROR [jeeves.service] - (C) Exc : java.lang.NullPointerException
2008-08-14 11:58:32,203 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
<message />
<stack>
</stack>
<request>
</request>
</error>
2008-08-14 11:58:32,203 INFO [jeeves.service] - -> dispatching to error for : portal.opensearch
2008-08-14 11:58:32,234 ERROR [jeeves.service] - Exception executing gui service : java.lang.NullPointerException
2008-08-14 11:58:32,234 ERROR [jeeves.service] - (C) Stack trace is :
2008-08-14 11:58:32,250 INFO [jeeves.service] - -> transforming with stylesheet : D:\Jboss\jboss-4.0.5.GA\server\default\.\deploy\geonetwork.war\/xsl/error.xsl
2008-08-14 11:58:32,343 INFO [jeeves.service] - -> end error transformation for : portal.opensearch
2008-08-14 11:58:32,343 INFO [jeeves.service] - -> error ended for : portal.opensearch
Thanks
