[GeoNetwork-users] Problems migrating from GN 2.6.4
Òscar
Generally the sql statement that is causing the issue is in the logs but I
don't see it in your logs. Maybe you got to go back further in the logs. You
would need to locate the first SQL error since it generally has a snowball
effect.
You can to run the scripts manually via pgsql but it may be a little time
consuming. To see the list of scripts to be executed you can look at the
following file.
config-db.xml
<https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/webapp/WEB-INF/config-db.xml&gt;
contains a list of all the db scripts from the migrate folder that will be
executed.
So in your case it will run the scripts from
v265
<https://github.com/geonetwork/core-geonetwork/tree/2.10.x/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v265&gt;
v280
<https://github.com/geonetwork/core-geonetwork/tree/2.10.x/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v280&gt;
v2100
<https://github.com/geonetwork/core-geonetwork/tree/2.10.x/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v2100&gt;
Alternatively, you could setup your new 2.10 installation to connect to a
new pg schema/user - then you can export the old data and import it in the
new installation.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-migrating-from-GN-2-6-4-tp5064692p5064956.html
Hi Ian,
I've found the problem
Installing GN in Spanish doesn't work
With english perfect installation in seconds
Best,
Òscar
Institut de Ciències del Mar (CSIC) at Barcelona
Passeig Marítim de la Barceloneta, 37-49
08003 Barcelona (Catalonia)
SPAIN
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-migrating-from-GN-2-6-4-tp5064692p5065989.html
Hi Ian,
When you said:
"... then you can export the old data and import it in the new installation.
Do you mean backup PostGIS DB GN 2.6.4 and restoring into PostGIS DB GN
2.10?
Best,
Òscar
SPAIN
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-migrating-from-GN-2-6-4-tp5064692p5066036.html
Òscar
No - I did not mean export/import at the database level. I was talking about
the export via GAST and the import could be done via the metadata import.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-migrating-from-GN-2-6-4-tp5064692p5066061.html
Hi Ian,
I've attached 2 printscreen of my GAST. I only have the choice to configure
database connection
gast1.jpg <http://osgeo-org.1560.x6.nabble.com/file/n5066091/gast1.jpg&gt;
gast2.jpg <http://osgeo-org.1560.x6.nabble.com/file/n5066091/gast2.jpg&gt;
I've launched Gast from geonetwork/bin/gast.sh
I don't know if I miss something
Òscar
SPAIN
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-migrating-from-GN-2-6-4-tp5064692p5066091.html
You would need to export from 2.6.4 using gast
<https://github.com/geonetwork/core-doc-sources/blob/2.6.x/eng/users/source/admin/gast/gast-mef-export.png&gt;
Then in your new 2.10 installation, go to the the administrator section (in
the geonetwork web interface) and use the batch import
<https://github.com/geonetwork/core-geonetwork/blob/2.10.x/docs/eng/users/source/managing_metadata/import/web-batchimport-where.png&gt;
tool.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-migrating-from-GN-2-6-4-tp5064692p5066405.html
