I try to integrate open software geonetwork 2.1
for project that I do in university for a department of “Generalitat de catalunya” in Catalonia,
Spain.
I write you because I have a problem when I create
my own metadata schema. The problem is that this schema doesn’t appear in list
of templates when I go to create new metadata as administration. I create my
own template using tutorial “Geonetwork schema/template howto”.
Have you delete some part that are integrated in the search parameters like
geographic bounding box as exemple ?
I have seen that when some part are deleted the search engine can't find the
metadata after the deletion.
What is your own metadata schema ?
A profile of the ISO19139 ?
Best regards,
Fabien Bachraty
Enric . wrote:
Hello list,
Spain.
list
my
