[GeoNetwork-users] Problems with Dublin Core
Hi Jeroen!
Could you help me, please.
When I'm trying to create new Dublin Core metadata, GeoNetwork says
something like that: "Operation could not be performed", and message appears
in the log file:
"2007-10-07 16:39:41,296 ERROR [jeeves.service] - Exception when executing
service
2007-10-07 16:39:41,296 ERROR [jeeves.service] - (C) Exc :
java.lang.IllegalArgumentException: Mismatch between schema and xml: No type
for 'element' : dc:title with parent simpledc
2007-10-07 16:39:41,296 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
  <message>Mismatch between schema and xml: No type for 'element' : dc:title
with parent simpledc</message>
  <class>IllegalArgumentException</class>
  <stack>
    <at class="org.fao.geonet.kernel.schema.MetadataSchema" file="
MetadataSchema.java" line="89" method="getElementType" />
    <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java" line="541"
method="expandElement" />
    <at class="org.fao.geonet.kernel.EditLib" file=" EditLib.java"
line="464" method="expandTree" />
    <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java" line="473"
    <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java" line="130"
method="addEditingInfo" />
    <at class="org.fao.geonet.kernel.DataManager" file=" DataManager.java"
line="643" method="getMetadata" />
    <at class="org.fao.geonet.services.metadata.GetEditableData" file="
GetEditableData.java" line="72" method="exec" />
    <at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java"
line="238" method="execService" />
    <at class="jeeves.server.dispatchers.ServiceInfo " file="
ServiceInfo.java" line="141" method="execServices" />
    <at class="jeeves.server.dispatchers.ServiceManager" file="
ServiceManager.java" line="372" method="dispatch" />
  </stack>
  <request>
    <language>ru</language>
    <service>metadata.edit</service>
  </request>
  <request>
    <id>8</id>
    <forward service=" metadata.create" />
  </request>
</error>
2007-10-07 16:39:41,296 INFO [jeeves.service] - -> dispatching to error
for : metadata.edit
2007-10-07 16:39:41,671 INFO [jeeves.service] - -> transforming with
stylesheet : C:\GeoNetwork\web\geonetwork\/xsl/error.xsl
2007-10-07 16:39:41,765 INFO [jeeves.service] - -> end error
transformation for : metadata.edit
2007-10-07 16:39:41,765 INFO [jeeves.service] - -> error ended for :
metadata.edit".
I have to fix it up as soon as possible.
Please help me, I'll really appreciate it.
PS: If this problem is already fixed, please tell me where I can get
solution.
(I don't want to download full distribution again.)
Thank You,
Igor V. Burago
Hi Igor,
Yes, the problem was know just before the release :frowning:
It has now been resolved for what concerns the editing. The updated code is in the SVN code repository and will be part of a fix release soon. This doe snot help you very much I guess, except when you build the application from SVN.
I discovered a new error I think in that after editing and saving, the record is not properly indexed and hence not found in the results. I'll file a bug report for that to make sure that's also resolved before the fix release.
Sorry for the inconvenience.
Ciao,
Jeroen
On Oct 13, 2007, at 7:01 AM, Igor V. Burago wrote:
Hi Jeroen!
When I'm trying to create new Dublin Core metadata, GeoNetwork says something like that: "Operation could not be performed", and message appears in the log file:
"2007-10-07 16:39:41,296 ERROR [jeeves.service] - Exception when executing service
2007-10-07 16:39:41,296 ERROR [jeeves.service] - (C) Exc : java.lang.IllegalArgumentException: Mismatch between schema and xml: No type for 'element' : dc:title with parent simpledc
2007-10-07 16:39:41,296 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
  <message>Mismatch between schema and xml: No type for 'element' : dc:title with parent simpledc</message>
  <stack>
    <at class="org.fao.geonet.kernel.schema.MetadataSchema" file="MetadataSchema.java" line="89" method="getElementType" />
    <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java" line="541" method="expandElement" />
    <at class="org.fao.geonet.kernel.EditLib" file=" EditLib.java" line="464" method="expandTree" />
    <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java" line="473" method="expandTree" />
    <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java" line="130" method="addEditingInfo" />
    <at class="org.fao.geonet.kernel.DataManager" file=" DataManager.java" line="643" method="getMetadata" />
    <at class="org.fao.geonet.services.metadata.GetEditableData" file="GetEditableData.java" line="72" method="exec" />
    <at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="238" method="execService" />
    <at class="jeeves.server.dispatchers.ServiceInfo " file="ServiceInfo.java" line="141" method="execServices" />
    <at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="372" method="dispatch" />
  </stack>
  <request>
  </request>
  <request>
    <id>8</id>
  </request>
</error>
2007-10-07 16:39:41,296 INFO [jeeves.service] - -> dispatching to error for : metadata.edit
2007-10-07 16:39:41,671 INFO [jeeves.service] - -> transforming with stylesheet : C:\GeoNetwork\web\geonetwork\/xsl/error.xsl
2007-10-07 16:39:41,765 INFO [jeeves.service] - -> end error transformation for : metadata.edit
2007-10-07 16:39:41,765 INFO [jeeves.service] - -> error ended for : metadata.edit".
PS: If this problem is already fixed, please tell me where I can get solution.
Thank You,
Igor V. Burago
Hi Simon!
Yes, I'm using 2.1 final release. (Patch isn't necessary for 2.0.3.)
I need to make a stable system using GeoNetwork as soon as possible.
If my attempts with 2.1 will be unsuccessful, then I switch back to 2.0.3.
Thank You,
Igor V. Burago
2007/10/15, Jeroen Ticheler <Jeroen.Ticheler@anonymised.com>:
Hi Igor,
Ciao,
Jeroen
> Hi Jeroen!
> executing service
> <error id="error">
> <stack>
> </stack>
> <request>
> </request>
> <request>
> <id>8</id>
> </request>
> </error>
> error.xsl
> get solution.
> Thank You,
> Igor V. Burago
