[GeoNetwork-users] Problems with Dublin Core
Hello List,
I have to build a full functionally server version of GeoNetwork until end of december. We have plenty of data without a geographical content in our project, so I want to use the Dublin Core template to manage this kind of data. I read in the mailinglist that there will be a "fix release soon" (...14th october), that will rectify the problem with DC-template.
I am using eclipse including subclipse so I tried to build the application from SVN after running the build.xml from installer-folder [trunk]. The results seem to be correct, but after installing GN the DC template doesn't work as well.
this error appears...
The requested operation could not be performed.
IllegalArgumentException: Mismatch between schema and xml: No type for 'element': null with parent simpledc
So my questions...
1) Is there a "date" when the GN update will be released ?
2) Does anyone fixed the problem by using SVN to build the application?
3) I dont want to change some files (e.g. layout, css, template...) per copy and paste. Thats why I'm trying to modify sourcecode using eclipse. I think it isn't necessary to build the complete application after changing some simple contend. How can I manage this ?
Thanks for your explanatory notes.
Best regards,
Christian
Christian Gadge
-Datenmanagement-
Helmholtz-Center of Environmental Research
Leipzig, Germany
Hello Christian,
I think that the ISO19115 can also describe data that are not geo localized,
The geographic bounding box and field concerning the geo localized data can
be delete.
What can the most can the less.
Moreover if you use the same standard for all your data this will be more
coherent.
You can create a template for geo localized data and non geo localized data.
Cordially Fabien Bachraty.
Christian Gadge wrote:
Hello List,
So my questions...
Best regards,
Christian
Christian Gadge
-Datenmanagement-
Leipzig, Germany
SF.Net email is sponsored by:
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
GeoNetwork-users mailing list
View this message in context: http://www.nabble.com/Problems-with-Dublin-Core-tp14273557s18419p14273786.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
I am newbie in GeoNetwork.
I agree with Fabien. The ISO 19115 is an extensible standard with only 10 mandatory attributes, its use is not restricted to georeferenced data.
For example, the datatype describing Responsible Party, Location or others are very global, thus applicable in other contexts: organisation database...
In my point of view, the context and the specific Metadata profile will give the usage of the Metadata standard and not the inverse.
Best regards,
Cyril Faucher.
FBachraty a écrit :
Hello Christian,
be delete.
coherent.
Hello List,
So my questions...
Best regards,
Christian
Christian Gadge
-Datenmanagement-
Leipzig, Germany
