[GeoNetwork-users] Problems with http-PUT and http-DELETE methods
Hello,
we had in our company a security test for the geonetwork. It shows that we
had some problems with open
http-PUT and http-DELETE methods. The http-PUT and http-DELETE methods are
open in the path /geonetwork/srv/api and selections. I’m not sure if this is
a problem by geonetwork or with our server. Maybe you can tell me if these
methods necessary for geonetwork or how it is possible to not allow these
methods?
Thank you.
Kind regards,
Tanja
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Hi, If you remove PUT/DELETE from the api/selections then you just drop the
selection mechanism. So it is probably not a good idea!
Cheers.
Francois
Le ven. 15 nov. 2019 à 11:12, Tanja <tanja.ruecker@anonymised.com> a
écrit :
Hello,
is
methods?
Thank you.
Kind regards,
Tanja
Sent from:
GeoNetwork-users mailing list
