l have a small question on geonetwork 2.2 precisely with Geoserver or
Intermap
I have inserted few polygon shapefiles on Geoserver, when I want to
display this shapefiles on Intermap, I query the Local Geoserver Web mapping
Server and select the polygon‘s shapefile.
Results: I have just some points which are good situated but not the
polygon. Is there an option or details which I have forgotten during the
insert of the shapefiles in Geoserver? I have already sucessfully integrated
some shape in previous version of Geoserver.
Thanks a lot for the answers
Hi Benjamin,
Did you ceck that the layer displays correctly in the GeoServer embedded demo using OpenLayers? Did you select a polygon style when configuring the layer?
Ciao,
Jeroen
On Apr 7, 2008, at 8:03 PM, INRH wrote:
Intermap
