[GeoNetwork-users] projectionlist
I want to add some projections into the projectionlist in the toolbar of the mapwindow. I wrote the following lines in config-gui.xml:
Now the projections appear in the projectionlist but if I choose one of them either the map is blanc or the map appears arbitrarily in the map window.
Only f I comment out the >proj> -Block mentioned above the mapwindow works fine with the projection given in the mapviewer options (<mapViewer options="{projection: ‘EPSG:31463’,units: ‘m’, maxExtent: …)
Any idea how to manage it correctly?
Regards
Lu
Neu: WEB.DE De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
Jetzt De-Mail-Adresse reservieren: https://produkte.web.de/go/demail02
