UNCLASSIFIED
I have recently installed GeoNetwork opensource 2.4.2. I have
configured a proxy with a username and password in the system
configuration settings area. This is an example of what is returned from
xml.config.get:
<config>
<proxy>
<use>true</use>
<host>my_proxy</host>
<port>8080</port>
<username>username</username>
<password>password</password>
</proxy>
</config>
My problem is that when I run a harvesting job (W*S) I get a response
from my proxy requesting authentication. I've monitored the traffic
from GeoNetwork (using Wireshark) and it looks like the username and
password is not being sent.
Has anyone else had this problem? Am I missing something in my
configuration?
Thanks in advance
Andrew Dwyer
IMPORTANT: This email remains the property of the Australian Defence
Organisation and is subject to the jurisdiction of section 70 of the
Crimes Act 1914. If you have received this email in error, you are
requested to contact the sender and delete the email.
