Hello all,
I am trying to publish shapefiles to GeoNetwork 3.0 using GeoServer.
First I've zipped all my shapefiles to an archive named like the files I want to publish e.g. shapefiles.zip containing .shp, .shx, .prf and .dbf files.
Secondly I went to create a new metadata using the ISO 19139 template. And uploaded the .zip file using the + Online Resources link. Now there is a button named "publish as wms, wfs, wcs". Clicking on it will let me choose the .zip file I've uploaded and I can choose the Geoserver I've added in the settings menu.
Thirdly I want to publish them by clicking on the "publish" link but nothing happens. A GET request is requested to the following URL:
http://server_url/geoserver.publisher?_content_type=json&&access=private&action=CREATE&file=shapefiles.zip&metadataAbstract=shapefile+test&metadataId=9824&metadataTitle=shapefiles&metadataUuid=486408ff-a682-4f7e-b821-7512ec8787a4&nodeId=4635
As response to the GET request I do get:
"@type": "vector",
"@status": "The data \"null\" is not legal for a JDOM attribute: A null is not a legal XML value."
My GeoServer is configurated like this:
Rest API config-url: http://server_url/geoserver/rest
workspace: shapefiletest : http://server_url/geoserver/rest/workspaces/
wms: http://server_url/geoserver/wms
wfs: http://server_url/geoserver/wfs
wcs: http://server_url/geoserver/wcs
styler: http://server_url/geoserver/var/www/styler/index.html
How do and where I change the "@type":"vector" so it will be a valid XML value?
Kind regards,
Sebastian
2015-05-26 15:20 GMT+02:00 Sebastian Hübner <
sebastian.huebner@anonymised.com>:
Hello all,
files.
One guess, do you follow this rule "In case of ZIP compression, ZIP file
base name must be equal to Shapefile or GeoTiff base name (ie. if the
shapefile is rivers.shp, ZIP file name must be rivers.zip).". In your case,
do you have shapefiles.shp in shapefile.zip ?
http://geonetwork-opensource.org/manuals/trunk/eng/users/quickstartguide/new_metadata/linking.html#link-your-data
HTH
Francois
"@type": "vector",
value?
Kind regards,
Sebastian
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
