[GeoNetwork-users] Publishing metadata
Hello,
I have GN 3.0.4 catalog. After log in as an administrator I can see on the
main page next to Browse resource icon that there is more than 28600
records. However after log out as a normal user I can see only 27900
records. I found some records that hadn't been published and after
publishing them the number of records visible for normal user increased.
My question is if there is any way how to filter just unpublished metadata
records so I can publish them at once.
thanks in advance.
Adam
Hi
I have check in 3.2.x branch and can't find any UI option to filter results
(you can filter records published to group ALL, but can't filter the
records not published to that group).
What is available is the following report: http://SERVER/geonetwork/srv/
eng/admin.console#/reports/report-internal-metadata
That should produce a CSV file with all records not published to the group
ALL. I guess the report is also available in 3.0.x.
An enhancement could be to add a new field in the index that tracks if the
metadata is public or not and could be use as a facet filter in the editor
dashboard to display published or unpublished metadata only. Please open a
issue in GitHub for this, thanks.
Jose García
On Thu, Sep 7, 2017 at 10:49 AM, Adam Laža <ad.laza32@anonymised.com> wrote:
Hello,
thanks in advance.
Adam
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
