[GeoNetwork-users] Query on Validation
Hello,
In Metadata.xsl we have the following statements. I would like to know where
from min ='1' is being set. I notice that this attribute is being used to
check for mandatory.I want to change min=0 so that red boxes do not appear
in the metadata editor form. Amy help in this regard is really appreciated.
<xsl:if test="(
(name(.)='gmd:LocalisedCharacterString' and ../../geonet:element/@min='1')
or ../geonet:element/@min='1'
) and $edit">
<xsl:attribute name="onkeyup">validateNonEmpty(this);</xsl:attribute>
</xsl:if>
Thanks in advance
Regards
Kumaran
Hi Kumaran,
Are you sure you want to do that? If you make a mandatory field optional then you will not have an ISO TC 211 compliant XML record.
On Monday, 11 April 2011 10:16 PM Kumaran Narayanaswamy wrote:
Hello,
like to know where
being used to
do not appear
really appreciated.
Hi Kumaran,
Thanks.
John
<xsl:if test="(
) and $edit">
</xsl:if>
Thanks in advance
Regards
Kumaran
Xperia(TM) PLAY
It's a major breakthrough. An authentic gaming
smartphone on the nation's most reliable network.
And it wants your games.
http://p.sf.net/sfu/verizon-sfdev
GeoNetwork-users mailing list
