[GeoNetwork-users] Queryable Parameters in CSW
Hello,
I am adding a new Queryable parameter in config-csw.xml as follows
<parameter name="Email" field="electronicMailAddress"
type="SupportedISOQueryables" /> (also tried with AdditionalQueryables)
And in CSW Test Interface I pass the following parameter through Post
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot;
service="CSW" version="2.0.2" maxRecords="150" startPosition="1"
resultType="results" outputSchema="csw:IsoRecord">
  <csw:Query typeNames="gmd:MD_Metadata">
    <csw:ElementSetName>full</csw:ElementSetName>
    <csw:Constraint version="1.1.0">
      <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;
          <ogc:PropertyIsEqualTo>
            <ogc:PropertyName>Email</ogc:PropertyName>
<ogc:Literal>kumaran.narayanaswamy@anonymised.com</ogc:Literal>
          </ogc:PropertyIsEqualTo>
      </ogc:Filter>
    </csw:Constraint>
  </csw:Query>
</csw:GetRecords>
I get 0 records as output whereas I have one metadata record with the above
email address. Am I doing anything wrong to add a new parameter which can be
queried through CSW? Please help. Thanks.
Regards
Kumaran
Hi Kumaran
You need to add the field electronicMailAddress to the lucene index file
(xml/schemas/iso19139/index-fields.xsl) as I don't see it in default
configuration, and reindex again the metadata.
Jose García
On Mon, Jul 4, 2011 at 1:48 PM, Kumaran Narayanaswamy <
kumaran.narayanaswamy@anonymised.com> wrote:
Hello,****
I am adding a new Queryable parameter in config-csw.xml as follows****
type="SupportedISOQueryables" /> (also tried with AdditionalQueryables) **
And in CSW Test Interface I pass the following parameter through Post****
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot;\*\*\*\*
service="CSW" version="2.0.2" maxRecords="150" startPosition="1"****
resultType="results" outputSchema="csw:IsoRecord">****
  <csw:Query typeNames="gmd:MD_Metadata">****
    <csw:ElementSetName>full</csw:ElementSetName>****
    <csw:Constraint version="1.1.0">****
      <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;\*\*\*\*
          <ogc:PropertyIsEqualTo>****
            <ogc:PropertyName>Email</ogc:PropertyName>****
<ogc:Literal>kumaran.narayanaswamy@anonymised.com</ogc:Literal>****
          </ogc:PropertyIsEqualTo>****
      </ogc:Filter>****
    </csw:Constraint>****
  </csw:Query>****
</csw:GetRecords>****
queried through CSW? Please help. Thanks.****
Regards****
Kumaran****
All of the data generated in your IT infrastructure is seriously valuable.
Why? It contains a definitive record of application performance, security
threats, fraudulent activity, and more. Splunk takes this data and makes
sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-d2d-c2
GeoNetwork-devel mailing list
Thanks Jose Garcia. That worked.
Regards
Kumaran
From: jose garcia [mailto:josegar74@anonymised.com]
Sent: Monday, July 04, 2011 5:37 PM
To: Kumaran Narayanaswamy
Cc: geonetwork-devel@lists.sourceforge.net;
geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Queryable Parameters in CSW
Hi Kumaran
Jose García
<kumaran.narayanaswamy@anonymised.com> wrote:
Hello,
      </ogc:Filter>
    </csw:Constraint>
  </csw:Query>
</csw:GetRecords>
Regards
Kumaran
