Good evening!
I need to implement an ATOM service that fulfills the INSPIRE requirements.
My customer wants to get a full Green/Yellow in the new validator: http://inspire-sandbox.jrc.ec.europa.eu/validator/
I have followed these instructions to set it up: http://geonetwork-opensource.org/manuals/trunk/eng/users/tutorials/inspire/download-atom.html
Is there any way to make the OpenSearch description document fulfill the INSPIRE requirements?
This is the one I've got after following the tutorial:
<OpenSearchDescription xmlns="http://a9.com/-/spec/opensearch/1.1/" xmlns:inspire_dls="http://inspire.ec.europa.eu/schemas/inspire_dls/1.0">
<ShortName>INSPIRE download service</ShortName>
<Description>
My INSPIRE Donwload service
</Description>
<Url type="application/opensearchdescription+xml" rel="self" template="http://myweb/geonetwork/opensearch/spa/atom_inspire/OpenSearchDescription.xml"/>
<Url type="application/atom+xml" rel="results" template="http://myweb/geonetwork/opensearch/spa/atom_inspire/describe"/>
<Url type="application/xml" rel="results" template="http://myweb/geonetwork/opensearch/spa/atom_inspire/search?any=\{filter\}"/>
<Contact>
Me me
</Contact>
<Tags>infoCoverageAccessService</Tags>
<LongName>
The long description here
</LongName>
<Developer>
Me
</Developer>
<Language>sp</Language>
</OpenSearchDescription>
This doesn't fulfill at least one of the requirements:
* TG Requirement 44: For each dataset available the OpenSearch description shall contain a 'Query' element that has a 'role' attribute with the value 'example' and 'spatial_dataset_identifier_code' and 'spatial_dataset_identifier_namespace' attributes together containing unique spatial dataset identifier. The value of the 'crs' and 'language' attributes shall be set to the values considered as the default ones by the service provider.
Any idea?
Thanks!
Best regards!
Óscar Diago Alonso
Desarrollador GIS / GIS Developer
Tel: +34 945131372 e-mail: mailto:oscar.diago@anonymised.com
Calle Pintor Clemente Arraiz, 3 Bajo 01008 Vitoria-Gasteiz
Geograma. Expertos en GeoInformación
[cid:image002.png@anonymised.com]
www.geograma.com<http://www.geograma.com/>
De acuerdo con la LO 15/1999, de Protección de Datos, y la Ley 34/2002 (LSSICE), se informa que su dirección de correo electrónico figura en nuestros archivos, al objeto de mantener el contacto y remitirle publicidad e información empresarial sobre las actividades de Geograma, S.L. Si no desea recibir publicidad e información empresarial sobre las actividades de Geograma SL le rogamos que nos lo comunique a la siguiente dirección de correo electrónico: geograma@anonymised.com<mailto:geograma@anonymised.com> Podrá ejercer los derechos de acceso, cancelación, rectificación y oposición reconocidos por la LOPD mediante solicitud escrita y firmada a Geograma, S.L. a la siguiente dirección C/ Castillo de Eskibel, 2 Bajo de Vitoria (C.P. 01007), adjuntando en todo caso copia de su DNI. En caso de modificación de sus datos deberá notificarlo en la misma dirección, declinando toda responsabilidad para la empresa en caso de no hacerlo. Si no es Ud. el destinatario y ha recibido este mensaje por error, agradecemos que lo comunique inmediatamente al remitente sin difundir, almacenar o copiar su contenido.
(attachments)
