I am useing Geonetwork 2.0.2 and want to make the harvesting feature work, but it seems I am not so fortunate. Definitely, the harvesting process is in progress, but I can only browse the harvested metadata records occasionally, that is, the harvested metadata records exist temporarily,and vanish with unknown reason. Can you figure out what is the problem? For your information, following are contents of the configureation file and the related log file.
Thank you very much!
The segment of the config file:
<schedules package="org.fao.geonet">
<!-- Examples of the 'when' attribute:
when='30 sec'
when='1 min'
when='12 hours'
when='1 hour, 30 min'
when='12 hours, 32 min, 13 sec'
<schedule name="geonetwork sync" class=".schedules.MetadataSync" when="1 min">
<param name="sites">
<site name="mapsondemand"> <!-- Servlet name of remote node -->
<general>
<host>193.43.36.137</host> <!-- domain name or IP of the remote host -->
<port>80</port> <!-- port of the remote host. Usually 80 or 8080 -->
<language>en</language>
<username></username> <!-- This field can be left empty to perform anonymous (guest) searches -->
<password></password> <!-- This field can be left empty to perform anonymous (guest) searches -->
</general>
<services>
<login>xml.user.login</login>
<logout>xml.user.logout</logout>
<search>xml.search</search>
<get>xml.metadata.get</get>
</services>
<search> <!-- These fields define the search parameters -->
<extended>off</extended>
<help>off</help>
<relation>equal</relation>
<any /> <!-- This field is the free text search field -->
<remote>off</remote>
<region/>
<paper>off</paper>
<siteId>OCHA</siteId> <!-- This is the unique site ID of the node information should be retrieved from. Can be used to set up trees of nodes -->
</search>
<search> <!-- By repeating the search blocks, you can define multiple searches on the same node -->
<help>off</help>
<any>areas</any>
<region/>
<paper>off</paper>
</search>
<group id="1"> <!-- These blocks define the groups and their privileges to be set for the harvested metadata -->
<privilege>view</privilege> <!-- Members of group 1 (internet/all) can see the metadata -->
<privilege>download</privilege> <!-- Members can download related resources -->
<privilege>dynamic</privilege> <!-- Members can see interactive resources -->
</group>
<group id="0">
<privilege>view</privilege> <!-- Members of group 0 (intranet) can see the metadata -->
</group>
</site>
</param>
</schedule>
<!-- Example of metadata harvesting
<schedule name="geonetwork harvest" class=".schedules.MetadataHarvest" when="30 sec">
<param name="configFile" value="/my/work/fao/geonet2/cvs/geonetwork/docs/examples/harvesting-config.xml"/>
</schedule>
</schedules>
I suggest you put in a harvesting schedule that is more in the order of hours than just 1 minute. Your extremely short repetitions in harvesting attempts may cause this behavior
Ciao,
Jeroen
On Jul 3, 2006, at 12:09 PM, Enri Zhou wrote:
when='30 sec'
when='1 min'
when='12 hours'
<general>
</general>
<services>
</services>
<help>off</help>
<region/>
<paper>off</paper>
</search>
<help>off</help>
<any>areas</any>
<region/>
<paper>off</paper>
</search>
</group>
<group id="0">
</group>
</site>
</param>
</schedule>
</schedule>
</schedules>
Thank you for your response. I changed the harvesting schedule from '1 minute' to '1 hour', but the same problem is still there. The log file also reflects the same thing.
Thank you in advance for your further instruction.
Enri
======= 2006-07-03 19:34:38 you wrote:=======
Ciao,
Jeroen
log file.
when='30 sec'
when='1 min'
when='12 hours'
when="1 min">
<general>
remote host -->
8080 -->
</general>
<services>
</services>
<help>off</help>
<region/>
<paper>off</paper>
trees of nodes -->
</search>
<help>off</help>
<any>areas</any>
<region/>
<paper>off</paper>
</search>
</group>
<group id="0">
</group>
</site>
</param>
</schedule>
</schedule>
</schedules>
Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your
job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo http://sel.as-us.falkag.net/sel?
cmd=lnk&kid=120709&bid=263057&dat=121642
Geonetwork-devel mailing list
Geonetwork-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
the harvesting is well configured and there are no errors on the log.
The question is: do you get this behaviour every time you start geonetwork?
If you got this only once, maybe someone has changed the privileges of those
metadata in the remote site.
when='30 sec'
when='1 min'
when='12 hours'
<general>
</general>
<services>
</services>
<help>off</help>
<region/>
<paper>off</paper>
</search>
<help>off</help>
<any>areas</any>
<region/>
<paper>off</paper>
</search>
</group>
<group id="0">
</group>
</site>
</param>
</schedule>
</schedule>
</schedules>
