[GeoNetwork-users] question about harvesting
Hi Hervé,
We are currently in the process of upgrading Geonetwork to the latest version. I do not think that the version of geonetwork that we are currently using (1.2.1) supports this functionality. We hope to complete the upgrade process within the next week or so.
You can access the current WHO geonetwork at http://www.who.int/geonetwork/
In the mean time, let me know if I can assist you.
Best regards,
Jason Pickering
Jason Pickering - Technical Officer
International Health Regulations Coordination
Public Health Mapping and GIS
CDS/EPR/IHR/GIS
World Health Organization
20, Avenue Appia
1211 Geneva 27
Switzerland
Tel: +41 22 791 5403
Fax: +41 22 791 4878
email:pickeringj@anonymised.com
From: geonetwork-users-bounces@lists.sourceforge.net [mailto:geonetwork-users-bounces@lists.sourceforge.net] On Behalf Of Hervé TRON
Sent: 30 November 2006 09:30
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] question about harvesting
Importance: High
Hello
We would like to harvest two websites
The WHO website.
Could you give us the information about the host and the port to use ?
We also would like to harvest the FAO website.
We’ve got 113 results directly from the website http://www.fao.org/geonetwork/srv/en/xml.search?any=africa+water&siteId=fao
But when we try to harvest, nothing happens.
Is the harvest above right ?
Thank you for your help
Hervé TRON
Office International de l’Eau
BP 75 - Place Sophie Laffitte
06902 Sophia Antipolis Cedex
Tel LD : 04 92 94 58 13
Tel : 04 92 94 58 00
Fax : 04 93 65 44 02
tecproda01.fao.org 8080 en xml.user.login xml.user.logout xml.search xml.metadata.get africa+water fao view download dynamic
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n’a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et privés.Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and private. Any total or partial publication, use or distribution must be authorized.
Ok,
Thank you for your very quick answer.
Do you know what’s wrong on the harvest from the FAO website ?
Could you help me please ?
I think the problem comes from the criterias of research.
I’m more in a hurry about the datas from the FAO.
Thank you
Regards
Hervé TRON
----- Message d’origine -----
De : PICKERING, Jason
À : Hervé TRON ; geonetwork-users@anonymised.comists.sourceforge.net
Envoyé : jeudi 30 novembre 2006 09:44
Objet : RE: [GeoNetwork-users] question about harvesting
Hi Hervé,
Best regards,
Jason Pickering
CDS/EPR/IHR/GIS
20, Avenue Appia
1211 Geneva 27
Switzerland
Importance: High
Hello
The WHO website.
Hervé TRON
Hi Hervé,
Yes, there’s a problem that prevents you from setting up harvesting using www.fao.org as the URL. Use tecproda01.fao.org instead with port 8080 and the problem should be solved.
Sorry for the inconvenience!
Ciao,
Jeroen
On Nov 30, 2006, at 10:25 AM, Hervé TRON wrote:
Ok,
Thank you
Regards
Hervé TRON
À : Hervé TRON ; geonetwork-users@anonymised.comceforge.net
Hi Hervé,
Best regards,
Jason Pickering
CDS/EPR/IHR/GIS
20, Avenue Appia
1211 Geneva 27
Switzerland
From: geonetwork-users-bounces@lists.sourceforge.net [mailto:geonetwork-users-bounces@anonymised.comurceforge.net] On Behalf Of Hervé TRON
Importance: High
Hello
The WHO website.
Hervé TRON
Any data and information contained in this electronic mail is personal, confidential and private. Any total or partial publication, use or distribution must be authorized.-------------------------------------------------------------------------
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys - and earn cash
GeoNetwork-users mailing list
GeoNetwork-users@anonymised.comsourceforge.net
Hi Jeroen.
I’m already using tecproda01.fao.org and the port 8080.
I would like to know if it’s possible to use more than one criteria of research or not ( I would like this result if possible http://www.fao.org/geonetwork/srv/en/xml.search?any=africa+water&siteId=fao ).
If yes, could you tell me how I’m suppose to write them ?
Hervé TRON
**tecproda01.fao.org** **8080** en xml.user.login xml.user.logout xml.search xml.metadata.get **** **africa+water** **fao** **** view download dynamic
De : Jeroen Ticheler
À : Hervé TRON
Cc : geonetwork-users@anonymised.comists.sourceforge.net
Envoyé : jeudi 30 novembre 2006 14:30
Objet : Re: [GeoNetwork-users] question about harvesting
Hi Hervé,Yes, there’s a problem that prevents you from setting up harvesting using www.fao.org as the URL. Use tecproda01.fao.org instead with port 8080 and the problem should be solved.
Ciao,
Jeroen
Hi Hervé,
It seems correct to me. Do you see anything in the log files? Remember that the first attempt will only be done after 10 minutes (that’s you schedule). While testing you may want to set it to 2 mins or so and change it after the first successful sync to something longer.Ciao,
Jeroen
On Nov 30, 2006, at 3:00 PM, Hervé TRON wrote:
Hi Jeroen.
Hervé TRON
À : Hervé TRON
Cc : geonetwork-users@lists.sourceforge.net
Ciao,
Jeroen
