[GeoNetwork-users] question registration and upload files
I just installed geonetwork
The installation is fine, but when I open my localhost geonetwork, it asks
me for a username and password.
*Where do I get the password?
*Is there a file where I have to set up my password? (I want to use it
using my PC as serverin a LAN)
*How do I upload my files?
Hi Vladimir
Check the related information here:
   http://geonetwork-opensource.org/manuals/trunk/eng/users/user-guide/quick-start/index.html#signing-in-and-load-templates
   http://geonetwork-opensource.org/manuals/trunk/eng/users/user-guide/associating-resources/index.html
Jose García
On Tue, Feb 14, 2017 at 2:29 PM, Vladimir Moya Quiroga Gomez <
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Thank you, its working.
One more question.
I can create new data, but I cannot import data.
I have shapefiles with metadata.
I go:
contribute -> Import New records
Upload from my computer
I select the xml metadata
Press +Import
I get green box "Import report"
But I cannot find my data
I tried assigning to a group and to a category
On Tue, Feb 14, 2017 at 10:32 PM, Jose Garcia <jose.garcia@anonymised.com>
wrote:
Hi Vladimir
   - http://geonetwork-opensource.org/manuals/trunk/eng/users/
   <http://geonetwork-opensource.org/manuals/trunk/eng/users/user-guide/quick-start/index.html#signing-in-and-load-templates&gt;
   <http://geonetwork-opensource.org/manuals/trunk/eng/users/user-guide/associating-resources/index.html&gt;
Jose García
GeoNetwork OpenSource is maintained at http://sourceforge.net/project
s/geonetwork
Hi Vladimir
The xml in the shapefiles are in a format not directly supported by
GeoNetwork, to import them in the import option there's a section *Apply
XSLT conversion*, you need to choose the option *ArcCatalog8_to_ISO19115*.
That will convert the xml from the shapefile to ISO19115 that is supported
in GeoNetwork.
The import process just manages about the metadata, but doesn't import and
link the shapefile to the metadata (this can be done later editing the
metadata in GeoNetwork and attaching the shapefile to it).
If you work usually with ESRI products like ArcMap and have quite metadata
to publish, maybe you can be interested in GeoCat Bridge (
https://www.geocat.net/bridge/). It's not an open source tool, but allows
the publication directly from ArcMap to GeoNetwork of the metadata and data.
Jose García
On Wed, Feb 15, 2017 at 4:23 AM, Vladimir Moya Quiroga Gomez <
One more question.
I go:
Press +Import
wrote:
Hi Vladimir
   - http://geonetwork-opensource.org/manuals/trunk/eng/users/use
Jose García
asks
s/geonetwork
Thanks
I tried but still nothing.
I also created a metadata in ISO19115
here I send 2 metadata samples
On Wed, Feb 15, 2017 at 4:20 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Vladimir
in GeoNetwork.
Jose García
One more question.
I go:
Press +Import
wrote:
Hi Vladimir
Jose García
asks
s/geonetwork
(attachments)
Fauna_JGD.shp.xml (61.9 KB)
Junctions.shp.xml (28.8 KB)
Hi
I have tested in 3.2.x and I get this error even when selecting the xslt
*ArcCatalog8_to_ISO19115*:
NoSchemaMatchesException
Autodetecting schema failed for metadata record with root element Metadata
in namespace [Namespace: prefix "" is mapped to URI ""].
That used to work properly in previous versions of GeoNetwork, seem
something has been broken. I would suggest to open a issue in GitHub to
track this better.
Jose García
On Wed, Feb 15, 2017 at 9:47 AM, Vladimir Moya Quiroga Gomez <
Thanks
wrote:
Hi Vladimir
in GeoNetwork.
and link the shapefile to the metadata (this can be done later editing the
metadata to publish, maybe you can be interested in GeoCat Bridge (
allows the publication directly from ArcMap to GeoNetwork of the metadata
and data.
Jose García
One more question.
I go:
Press +Import
wrote:
Hi Vladimir
Jose García
asks
s/geonetwork
