The default config option for 'Local Rating' in version 2.8.0 is that the enabled checkbox is un-checked and I have left it in that state, however I still see the ratings display on my records for both Firefox and IE8. Is there a way to manually disable/remove this option? Or am I misunderstanding that the checkbox is what makes the starred rating system display or not display on the record?
~Kathy
hi Kathy,
the local rating settings determines GeoNetwork's behaviour w.r.t. rating :
if local rating is enabled, ratings are only taken from your particular
GeoNetwork installation, otherwise the rating may be shared in a network of
GeoNetwork installations:
* User rating of metadata. If the metadata was harvested using the
'GeoNetwork' protocol and
* the system setting "localrating/enable" is false (the default), the
user's rating is shared
* between GN nodes partaking in this harvesting network. If the metadata
was not harvested or
* if "localrating/enable" is true then 'local rating' is applied, counting
only rating from
* users of this node itself.
* When a remote rating is applied, the local rating is not updated. It
will be updated
* on the next harvest run.
There is no setting to remove the rating display. You can remove the rating
display by editing the file /geonetwork/xsl/search-results-xhtml.js such
that you remove this section
<!-- metadata rating -->
<xsl:call-template name="rating">
<xsl:with-param name="info"
select="$metadata/geonet:info"/>
</xsl:call-template>
You'll probably need to restart the application to see this change.
Kind regards
Heikki Doeleman
~Kathy
Try New Relic Now & We'll Send You this Cool Shirt
New Relic is the only SaaS-based application performance monitoring service
that delivers powerful full stack analytics. Optimize and monitor your
browser, app, & servers with just a few lines of code. Try New Relic
and get this awesome Nerd Life shirt! http://p.sf.net/sfu/newrelic_d2d_apr
GeoNetwork-users mailing list
sorry, the file's name is /geonetwork/xsl/search-results-xhtml.xsl
On Mon, Apr 29, 2013 at 6:40 PM, heikki <tropicano@anonymised.com> wrote:
hi Kathy,
: if local rating is enabled, ratings are only taken from your particular
counting only rating from
will be updated
rating display by editing the file /geonetwork/xsl/search-results-xhtml.js
such that you remove this section
Kind regards
Heikki Doeleman
~Kathy
service
