Hi Syahmin,
Sorry for the late reply. I just uploaded the utility to the community website with some description. It really needs additional checking and probably improvements as described on the site. Look at the Software section on http://193.43.36.138/software/tools
I hope this helps. Contributions to the utility are very welcome!
Copying to the mailing-lists as other people were asking for the same.
Ciao,
Jeroen
On 23 Jan 2006, at 08:49, Syahmin Sukhairi wrote:
--Boundary_(ID_yjyQsDHLygvm3mkc9YO70w)
Content-type: text/plain; charset=ISO-8859-1
Content-transfer-encoding: 7BIT
Content-disposition: inlineHi,
i'm still waiting the utility like you said in your email before, or you can
tell me the url so i can download the software by my self.Thanks
Syahmin. SOn 1/11/06, Syahmin Sukhairi <syahmin@anonymised.com> wrote:
For Hydrobasins of Africa i have already try to edit and got same error,
and that's still happen if we install in XP machine (it was installed before
i put in 2003 machine).Thanks before for the utility.
Regards from Aceh, Indonesia
Syahmin. SOn 1/11/06, Jeroen Ticheler <Jeroen.Ticheler@anonymised.com> wrote:
Currently there is not a direct import from ArcMap metadata files. We
still need to add a transformation stylesheet in place to do that. It is
good to know that ArcMap does produce ISO metadata, but it does currently
not produce a "clean" metadata files as used by GeoNetwork that can be
imported directly. The ArcMap metadata files contain a lot of ESRI specific
content and also contain FGDC content.
I am tele-working now, but tomorrow I will send you a small utility that
can convert ArcMap metadata to GeoNetwork compliant ISO metadata and
backwards.
