[GeoNetwork-users] Re: Geonetwork 2 RC1 admin can't login
I have just installed Geonetwork 2 RC 1. I have one of the beta versions before
that and ran the uninstall jar. The McKoi database was not removed however???
When you uninstall, you should check the 'force uninstall' checkbox.
The new site seems to run smoothly (www.eis-africa.org:8080/geonetwork) but
when I try to login as administrator I get the message 'The requested operation
could not be performed' with no other information.
Please assist
thanks
Gavin
It seems that you cannot even do a search without logging in. Maybe the
database is not updated. Try to remove all files from the previous geonetwork
and install it again (or in another directory). Remember that you cannot keep
the database of the previous geonetwork release. You can obtain more
information from the log (catalina.out or jetty.log).
