[GeoNetwork-users] Re: GeoNetwork harvesting
Hi Frederik,
I have tested harvesting from your site and that works also with the old version! I guess that your problem was related to the privileges settings. Metadata is now by default NOT visible on the internet and intranet, you explicitly have to change these for each metadata (behaviour depends on defaults set in the database and can be customized to your own wishes, but this is the default behavior). This also means that if you create a specific group and/or user to be used by another node for harvesting, only metadata that is visible on the internet or visible to that specific user will be harvested by that remote node. Andrea's suggestion to first log on to the website using the username and pw for that "harvesting" user to see what comes up can be helpful, although intranet metadata might trouble the view :frowning:
Hope this helps.
Ciao,
Jeroen
On 23 Sep 2005, at 21:38, Andrea Carboni wrote:
Hi guys,
I made another test on geonetwork's harvesting capabilities. I couldn't find any
problem (the test went fine). I think that the problems with harvesting are related
to the bug fixed in beta4 and related to groups. As a rule of thumb, before trying
to harvest from a site you should see if a normal search gives results: when you
see results using a browser you can hope to harvest metadata.
