sorry, i forgot the list
---------- Weitergeleitete Nachricht ----------
Betreff: Re: [GeoNetwork-users] Geonetwork to wms
Datum: Dienstag 28 Juli 2009
Von: Armin Retterath <armin.retterath@anonymised.com>
An: Ryan.Fraser@anonymised.com
hi ryan,
sorry - we don't use geonetwork for managing the metadata of the webservices.
we use a service registry which is simply based on an adopted mapbender data
schema. so we have all wms, layer, wfs, featuretypes, as single objects in a
relational postgres/postgis schema available. this is much more easier than
have them in the geonetwork metadata table. if you use the geonetwork schema
for managing this resources, you must read out the information of the
metadata table - column 'data' - and parse the relevant infos for your
webservice it into a spatial table. i would recommend, to install some
database triggers to do this. our goal is not only to serve metadata but to
give access to the services and manage them on a simple way.
we plan to integrate geonetwork as a metadata editor and maybe as integration
system to collect different geonetwork nodes. the services are out of scope,
cause many relevant information about services (availability, monitoring
status, authorization, ...) cannot be interchanged by the use of CSW 2.0.2.
or any other catalogue service - till now.
regards
armin
Am Dienstag 28 Juli 2009 09:10:28 schrieben Sie:
Hi Armin
That application looks neat. I've managed to get my Geoserver wms pointing
to the shapefile however currently it only shows an ID on getFeatureInfo. A
couple of questions: * How do I configure the wms (Geoserver) to point to a
webservice to provide metadata * which web service will provide the data?
GeoNetwork or have you crafted one that extracts the info from GN?Thanks
Ryan-----Original Message-----
From: Armin Retterath [mailto:armin.retterath@anonymised.com]
Sent: Wednesday, 8 July 2009 2:57 PM
To: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Geonetwork to wmshello ryan,
if this shapefile exists in your implementation this is really simple. you
have only one problem: you must create a link in your getfeatureinfo
response which points to a webservice that give you the metadata (mayba in
html or xml). this can be easily be done be mapservers template
functionality. we' ve done somthing similar. in http://www.geoportal.rlp.de
you can search for a wms layer which is called 'layerumringe' (use the left
search form) and add this layer to our client. for us, this is a easy way
to see which regions the registrated wms layers cover. with a
getfeatureinfo on the
layerextent-layer you can get a list of all layers which covers this point
and have look at their metadata.
cheers
arminAm Mittwoch 08 Juli 2009 03:49:24 schrieb Ryan.Fraser@anonymised.com:
> Thanks to everyone else that responded.
> So Francois, if I understand correctly - I should be able to configure
> Geoserver to point at this shapefile and my whole (whatever records have
> been updated recently) should be "exposed" via wms - ie: the lat/long
> point or bounding box of each record would be shown in an image served
> via wms.
> Please confirm
> Cheers
> Ryan
> From: Francois Prunayre [mailto:fx.prunayre@anonymised.com]
> Sent: Wednesday, 8 July 2009 5:57 AM
> To: Fraser, Ryan (E&M, Kensington)
> Cc: geonetwork-users@lists.sourceforge.net; Pigot, Simon (CMAR, Hobart)
> Hello Ryan, if you're testing latest 2.4RC have a look to
> web/geonetwork/WEB-INF/lucene/spatial. Here is a shapefile used for
> spatial search and indexing. Basically, this shapefile is updated
> everytime a metadata record is updated and as such contains you're
> catalogue spatial footprint.
> The structure is quite simple, one geometry by record (which could be
> complex - bbox or multipolygon according to what you defined in your
> metadata) and one column with the metadata record id. This one is used
> for CSW spatial search.
> I've already tested to add a WMS on that shapefile, that's quite easy.
> Then rendering those information could be more difficult.
> Another option is to only render bbox on search, this has been done
> using OpenLayers vector support (see geocat.ch sandbox for example).
> Ciao. Francois
> 2009/7/7 <Ryan.Fraser@anonymised.com>:
> > Hi all
> > I was wondering if anyone could point to some instructions on
> > configuring the Geoserver (packaged with GN) to serve the GeoNetwork
> > database via wms? Essentially I would like a wms/portrayal of the
> > records available in the geonetwork database - please advise? Cheers
> > Ryan
> >-- ----- Enter the BlackBerry Developer Challenge
> > This is your chance to win up to $100,000 in prizes! For a limited
> > time, vendors submitting new applications to BlackBerry App World(TM)
> > will have the opportunity to enter the BlackBerry Developer Challenge.
> > See full prize details at: http://p.sf.net/sfu/blackberry
> > _______________________________________________
> > GeoNetwork-users mailing list
> > GeoNetwork-users@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> > GeoNetwork OpenSource is maintained at
> > http://sourceforge.net/projects/geonetwork
>-- --- Enter the BlackBerry Developer Challenge
> This is your chance to win up to $100,000 in prizes! For a limited time,
> vendors submitting new applications to BlackBerry App World(TM) will have
> the opportunity to enter the BlackBerry Developer Challenge. See full
> prize details at: http://p.sf.net/sfu/Challenge
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
Im Auftrag
Armin Retterath
beim
56073 Koblenz
