[GeoNetwork-users] Re: Geonetwork v2
> Hi !
> I just download Version 2, and it seems much faster than v1. Some
> questions
> about it ...
> - I get an error message when adding metadata :
> "Service not found.
> Service not found : metadata.add.form "
That service is not supported anymore (it has been removed).
Use the metadata import facility.
Using this facility you can apply a stylesheet when importing
metadata. Write your stylesheet and put it into the
web/xsl/batch-import directory. Then, go to the batch import
admin page and choose your stylesheet from the list.
> - Table datalocation doesn't exist anymore, ... How to manage
> overview in v2. I import XML from v1 to v2. Where do I have
> to put overviews.
This part is under development. You have to wait a while.
> - French is active but no translation is available. If you need
> help on that
> point let me know.
Thanks. We will contact you before the final candidate will be out.
> Thanks for your help.
> Francois
