Hi Francois,
I'm not sure all your questions were answered so far?
I'll reply to them inline below as far as I can.
On 8 Jun 2005, at 12:18, François Prunayre wrote:
Hi !
I just download Version 2, and it seems much faster than v1. Some questions
about it ...- I get an error message when adding metadata :
"Service not found.
Service not found : metadata.add.form "
This function needs updating. The new concept for adding new records is that you can store metadata as records or as templates. You can than use the templates you created as the starting point for new records. You can also duplicate existing metadata records to quickly create new entries.
We will have to replace the current metadata add function with a dropdown list showing all the available templates.
Templates use the same privileges mechanism that normal metadata does, so you can have custom set of templates for the different user groups.
- Table datalocation doesn't exist anymore, ... How to manage overview in
v2. I import XML from v1 to v2. Where do I have to put overviews.
Need some work it seems
- French is active but no translation is available. If you need help on that
point let me know.
Thanks, we just received the Spanish translation and will add that one. We will add the others as soon as someone does the job or near the moment we complete most functions so they don't require much updating in the process. You are welcome to contribute though!
Ciao,
Jeroen
Thanks for your help.
Francois-----Message d'origine-----
De : geonetwork-users-admin@lists.sourceforge.net
[mailto:geonetwork-users-admin@lists.sourceforge.net] De la part de
francisco.manas@...12...
Envoyé : mercredi 8 juin 2005 11:02
À : Jeroen Ticheler
Cc : geonetwork-users@lists.sourceforge.net;
Objet : RE: [GeoNetwork-users] ArcCatalog and GeonetworkThanks for the help, both of you.
We have tried to configure ArcCatalog to save the info in ISO format, but no
matter the preferences we set, it seems that it always saves de data in its
own format.Knowing that we can transform ArcCatalog's XML into ISO XML using the XSLT
is good news. I have never worked with XSLT transformation, but its time to
learn, i guess.
As soon as I have any results, i'll post about it.-------------------------------------------------------
This SF.Net email is sponsored by: NEC IT Guy Games. How far can you
shotput a projector? How fast can you ride your desk chair down the office
luge track?
If you want to score the big prize, get to know the little guy.
Play to win an NEC 61" plasma display: http://www.necitguy.com/?r=20
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net--
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
rien de suspect n'a ete trouve.Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
distribution must be authorized.--
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
