Hey Bovorn Siriampairat,
Hey i tell you thank you so much u have SAVED me a lot of time for
figuring out, i have already done what you had instructed.
Now the thing is after this setup i can be able to start the server on
GeoNetwork opensource but this does not help me so much to load this
Geonetwork on the browser as i do this
http://192.168.1.5:8080/geonetwork or http://localhost:8080/geonetwork
what have i not done
please help
On 3/12/2009 9:39 AM, Bovorn Siriampairat wrote:
Hi Simon,
You can defined which java version you would like to use
with geonetwork sth. like this: /opt/jdk6.0.12/bin/java -jar
geonetwork2.2.jar
Bovorn
On Thu, Mar 12, 2009 at 1:14 PM, simon<simon@anonymised.com
<mailto:simon@anonymised.com>> wrote:Please am interested in Geonetwork, is there anybody who can help
me on
how to configure Geonetwork 2.2.0 on centos 5.2
what i know is that the following are requiremet* linux or windows platform
* java version 6 or higher
* tomcat 5 or higher
* mysql 5So the problem is coming when i want to remove the default java 1.4.2
and install version 1.6.0.12 where by the current state of the
server is
*java 1.4.2* is shown as the default but i have also installed *java
1.6.0.12* at /opt/ directory so problem is how to kick off the old
one and set the later one as the default.I have also managed to install tomcat5 and is running so the main
problem is the java so that i can start installing geonetworkKind
Regards
Web masterERMIS AFRICA
Box 17347
Nakuru - 20100
Tel +254 51 221 33 23
Mob. +254 725 885 889
Website http://www.ermisafrica.org/>
or
http://www.ermisafrica.com/>------------------------------------------------------------------------------
Apps built with the Adobe(R) Flex(R) framework and Flex
Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities.
Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based
development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
GeoNetwork-users mailing list
<mailto:GeoNetwork-users@lists.sourceforge.net>
http://sourceforge.net/projects/geonetwork------------------------------------------------------------------------
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.237 / Virus Database: 270.11.10/1996 - Release Date: 03/11/09 20:42:00
Regards
Web master
ERMIS AFRICA
Box 17347
Nakuru - 20100
or
Regards
Web master
ERMIS AFRICA
Box 17347
Nakuru - 20100
or
