[GeoNetwork-users] Re: How to apply extra XSL transformations
On 11-9-2013 13:41, John Brisbin wrote:
G'Day Frans,
CSW and INSPIRE compliance would be pretty important for a number of people.
Could you post the specifics of the problems that need to be fixed up
with the additional XSL?
Sure! Two problems were identified: Firstly, the root element csw:GetRecordsResponse needed to be removed. Secondly, the gmd:DateStamp element that is automatically generated contains a gco:DateTime instead of a gco:Date.
The xls script below should fix those two issues:
<?xml version="1.0"?>
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform&quot;
xmlns:gmd="http://www.isotc211.org/2005/gmd&quot;
xmlns:gco="http://www.isotc211.org/2005/gco&quot;&gt;
   <xsl:template match="@*|node()">
     <xsl:copy><xsl:apply-templates select="@*|node()" /></xsl:copy>
   </xsl:template>
   <xsl:template match="/*">
     <xsl:apply-templates select="node()" />
   </xsl:template>
   <xsl:template match="gmd:dateStamp">
     <gmd:dateStamp>
       <gco:Date><xsl:value-of select="substring-before(gco:DateTime, 'T')"/></gco:Date>
     </gmd:dateStamp>
   </xsl:template>
</xsl:stylesheet>
Frans
Thanks!
On 11/09/2013 21:10 PM, Frans Knibbe | Geodan wrote:
Hello,
We have set up a metadata service that should be INSPIRE-compliant.
However, there seem to be two small things wrong the response to a
GetRecords request. I have made a XSL script that fixes those problems.
I am trying to find a way to apply this script to the output, but so far
I have not succeeded. Could someone please advise? Is it possible to add
extra XSL transformations to standard CSW output? And if so, how should
it be done?
Thanks in advance,
Frans
How ServiceNow helps IT people transform IT departments:
1. Consolidate legacy IT systems to a single system of record for IT
2. Standardize and globalize service processes across IT
3. Implement zero-touch automation to replace manual, redundant tasks
http://pubads.g.doubleclick.net/gampad/clk?id=51271111&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained athttp://sourceforge.net/projects/geonetwork
*Geodan*
President Kennedylaan 1
1079 MB Amsterdam (NL)
T +31 (0)20 - 5711 347
E frans.knibbe@anonymised.com
www.geodan.nl <http://www.geodan.nl> | disclaimer <http://www.geodan.nl/disclaimer&gt;
