hi,
in file
<installation-directory>/web/geonetwork/xsl/searchform_simple_template.xsl :
look for
<table id="minimap_root">
and change it to
<table id="minimap_root" style="display:none;">
This will hide the left small viewer.
another question why doesn't it work fine for you? If you have installed
out-of-the-box, it should work fine ..
kind regards
Heikki Doeleman
On Fri, May 9, 2008 at 1:13 PM, aldiaz84 <aldiaz84@anonymised.com> wrote:
Hi! ,
I'm integrating an geonetwork aplication in my web, but i'll like that the
left small viewer doesnt appear, (mapviewer don't works fine for me, don't
show my map , and really not is necesary for my aplication) ,
how can i do it?
How can i modify the geonetwork apparence?
Are there any documentation about that? :-/
Thank You!!
View this message in context:
http://www.nabble.com/Remove-intermap-viewer-fron-mainpage-of-geonetwork-tp17145881p17145881.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
GeoNetwork-users mailing list
Inventions cannot, in nature, be a subject of property. -- Thomas Jefferson
