[GeoNetwork-users] Re strict access to map viewer to unregistered users
Hi. I'm implementing GeoNetwork and I'm trying to change the map viewer so
only can see it registered users. Can I somehow restrict access to map
viewer? Maybe can I do this through the file "user-profiles.xml"? Thanks for
your help
View this message in context: http://www.nabble.com/Restrict-access-to-map-viewer-to-unregistered-users-tp19606238p19606238.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
For my point of view this is not so simple because geonetwork embeded
intermap to display the interactives maps.
And the maps displayed on intermap are provided by a (or some) maps
server(s).
So even if you block the map consultation with intermap for the unregistered
user on geonetwork, the geoserver (or other wms server) service access will
stay available for all, isnt'it ?
For me as example there is no control available on geoserver consultation.
Everybody looking to the url >>
http://youradress:tomcatport/geoserver/mapPreview.do
will see the geoserver maps.
But maybe I miss something.
Best Regards, Fabien Bachraty
for your help
View this message in context: http://www.nabble.com/Restrict-access-to-map-viewer-to-unregistered-users-tp19606238p19607730.html
server(s).
unregistered user on geonetwork, the geoserver (or other wms server)
service access will stay available for all, isnt'it ?
so only can see it registered users. Can I somehow restrict access to map
for your help
You're right. Thank you
View this message in context: http://www.nabble.com/Restrict-access-to-map-viewer-to-unregistered-users-tp19606238p19622482.html
