Yea, works fine. Pay attention to the rights of the folders. (Owner should be the user that is running tomcat/jetty and should habe appropriate rights).
If you want to use the new jetty-version (because of ajp) just install it and copy the folders from geonetwork/web/* into the webapps-folder of jetty and run it. Works fine for geonetwork but I had some problems with the geoserver in gn (one machine worked, another not). Fixed it with help of http://geoserver.org/display/GEOSDOC/Dealing+with+native+JAI.
-------- Original-Nachricht --------
Datum: Thu, 23 Apr 2009 12:56:54 -0700
Von: Alex Mandel <tech_dev@anonymised.com>
An: geonetwork-users@lists.sourceforge.net
Betreff: Re: [GeoNetwork-users] Ubuntu
I've been following the 2.1 Instructions, there doesn't seem to be any
difference.
http://geonetwork-opensource.org/documentation/how-to/installing-geonetwork-2-1-0-on-ubuntuAlex
Page, Michael wrote:
> Does anyone have any notes or documentation on setting up 2.2 on Ubuntu
Server?
> Michael Page
> Geospatial Librarian, Emory Libraries
> Adjunct Faculty, Department of Environmental Studies
> Emory University
> michael.page@anonymised.com<mailto:michael.page@anonymised.com>
> (office) 404.727.2348
> This communication (including any attachments) is intended for the use
of the intended recipient(s) only and may contain information that is
confidential, privileged or legally protected. Any unauthorized use or
dissemination of this communication is strictly prohibited. If you have received this
communication in error, please immediately notify the sender by return
e-mail message and delete all copies of the original communication. Thank you
for your cooperation.
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensign option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
GeoNetwork-users mailing list
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger01
