Hello,
1. No SVN is required and message is hardcoded. Cannot be solved.
2. I am happy that I can help you with the fix.
3. solved
Olaf
Hello geonetwork developers,
this issue is not so important, because this issue is about log messages on the server and the application works even well if you don't fix these items.
1. Metadata deletion "SVN repository for metadata enabled but no repository available"
Message only disappers when SVN is configured.
see XmlSerializerSvn.java
if (svnMan == null) { // do nothing
Log.error(Geonet.DATA_MANAGER, "SVN repository for metadata enabled but no repository available");
Is the log level really error?
I haven't found a section in the user manual how to configure SVN to get rid of the error message.
2. I have fixed an error, but I down know the error message anymore. To reduce error logs I copied the file loc/eng/xml/i18n.xml to loc/ger/xml/i18n.xml.
3. "Can´t find bundle for base name messages locale de_DE" or "Can´t find bundle for base name messages locale eng"?
I don't know how to solve this issue.
Message appears at tomcat startup or metadata insertion.
Olaf
Olaf Scheidt
Werum Software & Systems AG
Wulf-Werum-Strasse 3
21337 Lüneburg
Tel: +49 4131 8307-807
Fax: +49 4131 8307-200
Mail: olaf.scheidt@anonymised.com<mailto:olaf.scheidt@anonymised.com>
Web: http://www.werum.de
USt-ID-Nr: DE 293 571 381
Sitz der Gesellschaft: Lüneburg
RG: Lüneburg HRB 204846
Vorsitzender des Aufsichtsrats: Dr. Hans Windauer
Vorstand: Christian Sommer (Vorsitzender), Thomas Menge, Carsten Stein
Thanks for your report and contribution.
Some error can sometime occur but are not critical
On Tue, Jul 7, 2015 at 12:36 PM, Olaf Scheidt <Olaf.Scheidt@anonymised.com> wrote:
Hello,
3. solved
Olaf
items.
Olaf
Olaf Scheidt
21337 Lüneburg
Don't Limit Your Business. Reach for the Cloud.
GigeNET's Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
