[GeoNetwork-users] reference to thesauri in metadata edit mode
Hello,
I installed GN from trunk yesterday in order to discover the new features to come in version 2.5.
I have one question related to the thesauri. When I add a keyword coming from a thesaurus (e.g. the Inspire theme RDF file available on SVN), the corresponding thesaurus title is filled in with the name of the thesaurus as referenced in GN (e.g. "external.theme.inspire_theme") instead of the actual name of the thesaurus. Similarly the reference date field is not filled in.
Is it done on purpose or did I miss something?
Thank you.
Best regards,
Paul
Paul Hasenohr
European Environment Agency
Kongens Nytorv 6
DK-1050 Copenhagen
Denmark
Tel: +45 33 36 72 58
paul.hasenohr@...751...
Hi Paul,
You did not miss anything! That is exactly the way that it is done, as
described in the proposal [1].
Indeed concerning the thesaurus title it could be improved by setting only
the thesaurus name (ie INSPIRE Theme).
Nevertheless, concerning date do you have any suggestion on how to handle
it?
Feel free to open a ticket for enhancements on that feature.
ciao,
Mathieu
[1] http://trac.osgeo.org/geonetwork/wiki/KeywordSelection
On Tue, Apr 27, 2010 at 2:06 PM, Paul Hasenohr
<Paul.Hasenohr@anonymised.com>wrote:
Hello,
filled in.
Thank you.
Best regards,
Paul
Paul Hasenohr
Kongens Nytorv 6
DK-1050 Copenhagen
Denmark
paul.hasenohr@anonymised.com
GeoNetwork-users mailing list
Hi
2010/4/27 Mathieu Coudert <mathieu.coudert@anonymised.com>:
Hi Paul,
it?
Maybe a mapping from SKOS "header" / concept scheme [1] (See last
example of that section) to an ISO Citation for thesaurus could be
added.
Then Thesaurus name, date, version, ... could be automatically added
from the thesaurus properties.
Paul, for the time being you have to set/update them manually using the editor.
Francois
[1] http://www.w3.org/TR/2005/WD-swbp-skos-core-guide-20051102/#secscheme
ciao,
Mathieu
Hello,
filled in.
Thank you.
Best regards,
Paul
Paul Hasenohr
Kongens Nytorv 6
DK-1050 Copenhagen
Denmark
Hi François and Mathieu,
Thank you for your answers.
Maybe as an alternative to trying to find the title, date and dateType info from the RDF file itself, it would be possible to modify the thesaurus upload functionality in order for the admin to provide a thesaurus title, date and dateType together with the RDF file.
If this makes sense to you, I can open a ticket for enhancement.
Best regards,
Paul
-----Original Message-----
Sent: Tuesday, April 27, 2010 4:47 PM
To: Mathieu Coudert; Paul Hasenohr
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] reference to thesauri in metadata edit mode
Hi
2010/4/27 Mathieu Coudert <mathieu.coudert@...54...>:
Hi Paul,
it?
added.
Francois
ciao,
Mathieu
<Paul.Hasenohr@...751...>wrote:
Hello,
filled in.
Thank you.
Best regards,
Paul
Paul Hasenohr
Kongens Nytorv 6
DK-1050 Copenhagen
Denmark
2010/4/28 Paul Hasenohr <Paul.Hasenohr@anonymised.com>:
I made one :
http://trac.osgeo.org/geonetwork/ticket/226
I did not set milestone because AFAIK we don't have support for that for now.
Ciao.
Francois
Best regards,
Paul
From: Francois Prunayre [mailto:fx.prunayre@anonymised.com]
Hi
Hi Paul,
it?
added.
Francois
ciao,
Mathieu
Hello,
filled in.
Thank you.
Best regards,
Paul
Paul Hasenohr
Kongens Nytorv 6
DK-1050 Copenhagen
Denmark
