[GeoNetwork-users] Remote Directory metadata_data
Good day,
I would ask them if anyone knows the ability to remotely configure the
directory (/ opt / tomcat / webapps / geonetwork / WEB-INF / data / data /
metadata_data) and i would like to have data from the metadata in another
different storage space, thank you.
Thanks...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remote-Directory-metadata-data-tp5172832.html
Remotely, you mean somewhere else in the filesystem ? Or using external storage protocols (NFS, FTP, etc) ? As far as I know, the latter is not possible, directly. I would say you then have to mount it properly, and make sure it is already available when your tomcat instance starts.
If your new place is accessible through the standard filesystem, your answer is in the User doc : http://geonetwork-opensource.org/manuals/2.10.3/eng/users/admin/advanced-configuration/index.html , see Setting the data directory
Jean
Le 13/11/2014 15:21, cbeltran a écrit :
Good day,
Thanks...
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://pubads.g.doubleclick.net/gampad/clk?id=154624111&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
*Jean Pommier -- pi-Geosolutions*
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
As Jean said, i would recommand you to add the line
-Dgeonetwork.dir=$GEONETWORK_DIR
in a config file of your tomcat.
Note that you can separate subfolder of the data dir, like schema, or data
with for example :
-Dgeonetwork.schema.dir=$GEONETWORK_SCHEMA_DIR"
On Thu, Nov 13, 2014 at 3:49 PM, Jean Pommier <
jean.pommier@anonymised.com> wrote:
Advanced configuration - GeoNetwork Opensource
Jean
> Good day,
> Thanks...
> geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Florent Gravin
Camptocamp - Chambéry
0479444492
Hi Jean
Thanks for your reply, I think storage in another server? Its possible??
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remote-Directory-metadata-data-tp5172832p5172856.html
Hi Florent
When yo refer -Dgeonetwork.dir=$GEONETWORK_DIR
what is the configuration file in tomcat?
Thanks???
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remote-Directory-metadata-data-tp5172832p5172857.html
Try to add
GEONETWORK_DIR=your_data_dir
export ADD_JAVA_OPTS="$ADD_JAVA_OPTS -Dgeonetwork.dir=$GEONETWORK_DIR
-Dfile.encoding=UTF8"
in for example tomcat/bin/setenv.sh
If you don't have it, just look for files that seem to update ADD_JAVA_OPTS
or CATALINA_OPTS
To check, restart your tomcat and geonetwork, and go into information
page /geonetwork/srv/eng/admin.console#/dashboard/information
On Thu, Nov 13, 2014 at 4:21 PM, cbeltran <cbeltran@anonymised.com> wrote:
Hi Florent
Thanks???
Florent Gravin
0479444492
Look
<http://osgeo-org.1560.x6.nabble.com/file/n5172869/geonetworkdata.png&gt;
And config this:
GEONETWORK_DIR=//192.168.11.70/metadata_data --> Its ok?
Thanks...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remote-Directory-metadata-data-tp5172832p5172869.html
I don't think so. At least not easily.
Maybe mounting a partition with NFS ? I guess you'll have to try...
Jean
Le 13/11/2014 16:17, cbeltran a écrit :
Hi Jean
Thanks
hi
Jean
I made the settings to make it a local storage:
nano setenv.sh --> on /opt/tomcat/bin/
GEONETWORK_DIR = / home / cbeltran / geonetwork
ADD_JAVA_OPTS export = "$ ADD_JAVA_OPTS -Dgeonetwork.dir = $ GEONETWORK_DIR
-Dfile.encoding = UTF8"
after
chmod +x setenv.sh
now
[root@anonymised.com bin]# export GEONETWORK_DIR=/home/cbeltran/geonetwork
and
[root@anonymised.com bin]# echo $GEONETWORK_DIR
Initially It works, I went that route and created the "geonetwork" folder
and within this entire structure:
index
data
config
Then I create a new metadata but the directory information is stored by
default in / opt / tomcat / webapps / geonetwork / WEB-INF / data / data /
metadata_data
and not in / home / cbeltran / geonetwork / data / metadata_data
finally restart and no longer work.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remote-Directory-metadata-data-tp5172832p5173668.html
I investigated, I did this:
In /geonetwork/WEB-INF/web.xml
This line:
Uncomment and modified
            <init-param>
            <param-name>geonetwork.dir</param-name>
            <param-value>/home/gic/geonetwork</param-value> --> local
directory
           </init-param>-->
restart tomcat, Now I will review the directory and did create the entire
directory structure
geonetwork/
|--data
| |--metadata_data
| |--resources:
| | |--htmlcache
| | |--images
| |--metadata_subversion
|--config:
| |--schemaplugin-uri-catalog.xml
| |--codelist:
| |--schemaPlugins
|--index:
| |--taxonomy
| |--index.
But I have a problem when I'm in geonetwork through the browser the
following error message:
TransformerConfigurationException : Failed to compile stylesheet. 1 error
detected.
Attached image.
Thanks...
<http://osgeo-org.1560.x6.nabble.com/file/n5173695/geonetworkerror.png&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remote-Directory-metadata-data-tp5172832p5173695.html
