Hello All!
Last year Paul Grzeszczak (pgrzeszc@anonymised.com) wrote a topic about remote
searching FGDC Clearinghouse nodes problem in geonetwork-devel mailing list:
<http://sourceforge.net/mailarchive/forum.php?thread_name=OF597D9D2B.C5A8F319-ON85257310.00612BF6-85257310.00630E3C%2540uwindsor.ca&forum_name=geonetwork-devel>
"Hi all,
I've been wondering why I get very brief, uninformative results when
searching FGDC clearinghouse nodes running Isite2 (
http://clearinghouse4.fgdc.gov/ftp/ ).
It turns out, that no matter the default_element_set_name
RepositoryProperty setting within geonetwork/web/xml/repositories.xml,
GeoNetwork always asks for the summary element set.
At the bottom is a log from the Isite2 zserver process that I installed to
figure out what's wrong. When retreiving actual record contents, the
message "Client has asked for element set name of s" always refers to
element set name of s even if repositories.xml specifies 'f'.
Is there any way to make it retrieve full metadata?
Paul
--- zserver log begin---
Connection has arrived...
Received connection...
Now up to 1 child process(es)
Waiting to Accept client...
SearchRequest: ReferenceID 7963093:srch
Searching ISEARCH Database test
Searching using a OPSTACK based query
Query type is 1
Attribute Set ID = 1.2.840.10003.3.9
Decoding AttributesPlusTerm.
Decoding attr list
3 attrs avail
USE=1016
Mapping: AttrSetId=1.2.840.10003.3.9
Mapping: Converting field from 'geo/1016' to Any
STRUCTURE=6
RELATION=3
Term = "water"
There were 4 hits.
Building return response records.
Server is returning record syntax of 1.2.840.10003.5.109.10
SearchResponse: ReferenceID 7963093:srch
PresentRequest: ReferenceID 7963093:0
Client has asked for 4 records, starting with record #1
Client has asked for element set name of b
Client has asked for record syntax of 1.2.840.10003.5.109.10
Record list built.
PresentRequest: ReferenceID 7963093:1
Client has asked for 1 records, starting with record #2
Record list built.
---log end---
Paul Grzeszczak
GIS Analyst / Programmer
tel. +1-519-253-3000 ext. 2531
Memorial Hall 211B
Dept. of Earth Sciences
University of Windsor ".
Now, using GeoNetwork 2.0.3, I faced with exactly the same problem.
May be by this time solution is known? Is it still impossible to make
GeoNetwork 2.0.3 retrieve full metadata?
This question is very important for me and my organization. I'll really
appreciate any help.
Thank You,
Igor V. Burago
