We would like to remove some unused templates so that they are unavailable to the user when we are creating a new record.
We only want to use 2-3 templates as our domain is quite specific.
Is there a way to do this so that when we install geonetwork on a new machine the unwanted templates are not available?
Many thanks.
Graeme
[Telespazio VEGA UK Ltd]
Graeme Shaw
Navigation, Telecoms & Ground Segment
350 Capability Green, Luton, Bedfordshire LU1 3LU - United Kingdom
Ph: +44 1582 399005
Graeme.Shaw@anonymised.com
telespazio-vega.com<http://www.telespazio-vega.com>
-WARNING: This message contains confidential and/or proprietary information which may be subject to privilege or immunity and which is intended for the use of its addressee only.
Should you receive this message in error, you are kindly requested to inform the sender and to definitively remove it from any paper or electronic format.
Any other use of this e-mail is strictly forbidden. Thank you in advance for your cooperation.
Please consider the environment before printing this e-mail.
Sure, remove them from the schema templates folder. See
http://geonetwork-opensource.org/manuals/trunk/eng/users/customizing-application/implementing-a-schema-plugin.html#contents-of-a-geonetwork-schema
for mode details).
HTH
Francois
2017-07-28 11:20 GMT+02:00 Graeme Shaw <Graeme.Shaw@anonymised.com>:
Many thanks.
Graeme
Graeme Shaw
Ph: +44 1582 399005
electronic format.
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
