On Wed, May 11, 2016 at 8:25 AM, Peck-Choo Tan <P.Tan@anonymised.com> wrote:
hi Maria,
Can you please HELP ME?
I got a system error when trying to remove a child record from a parent
(Geonetwork opensource application).
THE ERROR in the logs IS:The thesaurus
http://asdd.ga.gov.au/asdd/profileinfo/anzlic-theme.xml#anzlic-theme does
not exist, there for the query cannot be excuted: 'Query [query=SELECT
DISTINCT id,uppc,lowc,broader,eng_prefLabel,eng_note FROM {id} rdf:type
{skos:Concept},[{id} gml:BoundedBy {} gml:upperCorner {uppc}],[{id}
gml:BoundedBy {} gml:lowerCorner {lowc}],[{id} skos:broader {broader}],[{id}
skos:prefLabel {eng_prefLabel} WHERE lang(eng_prefLabel) LIKE "en" IGNORE
CASE],[{id} skos:scopeNote {eng_note} WHERE lang(eng_note) LIKE "en" IGNORE
CASE] WHERE (eng_prefLabel LIKE "GEOSCIENCES-Geology" IGNORE CASE OR id LIKE
"GEOSCIENCES-Geology" OR id LIKE "GEOSCIENCES-Geology") USING NAMESPACE
skos=<http://www.w3.org/2004/02/skos/core#>,gml=<http://www.opengis.net/gml#>,
interpreter=KeywordResultInterpreter]'On the Geonetwork UI, user gets this:
The requested operation could not be performed.
BadParameterEx: Processing failedI am using version is 2.10.1
Your help will be appreciated. Thanks
PeckPeck-Choo Tan
Analyst Programmer
Applications
GNS Science
1 Fairway Drive, Avalon, Lower Hutt 5010
New Zealand
DDI:+64-4-570 4739
Notice: This email and any attachments are confidential. If received in
error please destroy and immediately notify us. Do not copy or disclose the
contents.
