[GeoNetwork-users] Removing Templates from Sort List
I have discovered that, when in the admin module, if you select a template
schema and press Add templates, there is no check to see if you have
already done that previously. The result is that you end up with multiple
templates with the same name in the list when you go to sort them.
Is there a way to delete a template from the list if a duplicate exists?
Thanks Dean
2015-05-12 6:02 GMT+02:00 Dean Howell <deanhowell2009@anonymised.com>:
In 2.10, go to the search interface and filter on template to clean the
duplicates.
In 3.0, go to the editor board (
http://localhost:8080/geonetwork/srv/eng/catalog.edit), filter on template
facet and clean duplicates.
HTH.
Francois
Thanks Dean
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
