[GeoNetwork-users] repositories.xml
Hi All!!!!!
I have this problem in may GN installation..... (GN 2.4.1, Tomcat 6)
Tomcat log:
java.io.FileNotFoundException:
/usr/share/apache-tomcat-6.0.18/applications/geonetwork/web/geonetwork/loc/en/xml/repositories.xml
(No such file or directory)
This file is not present in my Geonework.
Any Suggestoins about this file???
Ing. Francesco D'Amore
blog: www.marinajonica.org
linkedin: http://www.linkedin.com/in/francescodamore
Consiglio Nazionale delle Ricerche - Istituto di Inquinamento Atmosferico (IIA)
Hi franko,
I haven´t got even such a file (and it works fine as far as I can see).
When do you get the exception?
franko wrote:
Hi All!!!!!
Tomcat log:
(IIA)
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
GeoNetwork-users mailing list
View this message in context: http://n2.nabble.com/repositories-xml-tp3829494p3829533.html
hi Francesco,
you may get this error if you accidentally started GeoNetwork from its
repository directory, not its installation directory. At least when using
Jetty to run it.
As you're running in Tomcat, could it be you did not produce an installed
environment to deploy, but you deployed the repo directory just-like-that ?
Kind regards
Heikki Doeleman
On Thu, Oct 15, 2009 at 4:08 PM, Sarah_S <Sarah_flip@anonymised.com> wrote:
Hi franko,
franko wrote:
> Hi All!!!!!
> Tomcat log:
> (IIA)
hi heikki,
do you mean that repositories.xml is needed in gn? I use win (used
geonetwork installer pack) and tomcat and deploy folders of gn, intermap and
geoserver to webapps directory at tomcat.
Did I something wrong?
thanks.
best regards
Sarah
Heikki Doeleman wrote:
hi Francesco,
Jetty to run it.
Kind regards
Heikki Doeleman
Hi franko,
franko wrote:
> Hi All!!!!!
> Tomcat log:
Atmosferico
> (IIA)
your
stay
View this message in context: http://n2.nabble.com/repositories-xml-tp3829494p3864309.html
I don't well understand what you mean.
I copied gonetwork directory in a folder in the server and added a context
tag in server.xml. Before that, I have configured with gast application the
database source, where metadata are sotred.
There is other way to do GN works in a tomcat server???
Thank you.
2009/10/16 heikki <tropicano@anonymised.com>
hi Francesco,
Jetty to run it.
Kind regards
Heikki Doeleman
> Hi franko,
> franko wrote:
> > Hi All!!!!!
> > Tomcat log:
Atmosferico
> > (IIA)
your
stay
> > _______________________________________________
(IIA)
I have seen this error in the Tomcat log when the database is not properly
setup. We use GN 2.4.2, Tomcat 5.5, Oracle 10.2.
Also, look for an SQLException or other exceptions in geonetwork.log for
more clues.
(There seem to several possible causes of this repositories.xml error.)
--Rich
> > Tomcat log:
View this message in context: http://n2.nabble.com/repositories-xml-tp3829494p4107744.html
