I am trying to install GeoNetwork 2 Beta 1on both a RedHat and Gentoo machine using TomCat 5 and J2SDK 1.4.2_07, On both machines I run through the whole installation dialog, then it just seems to hang and not complete. Any ideas? Should it deploy automatically or do I need to manually deploy it using TomCat administrator?
later…now it has completed the install process but is still not deploying properly. see www.eis-africa.org:8080/geonetwork
thanks
Gavin
Could you post your Tomcat Log & exceptions ?
Francois
De : geonetwork-users-admin@lists.sourceforge.net [mailto:geonetwork-users-admin@lists.sourceforge.net] De la part de Gavin Fleming
Envoyé : jeudi 21 juillet 2005 08:44
À : jeroen.ticheler@anonymised.com; geonetwork-users@lists.sourceforge.net
Objet : [GeoNetwork-users] resend: problem installing GeoNetwork
thanks
Gavin
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n’a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et privis.Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and private. Any total or partial publication, use or distribution must be authorized.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et privés.Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
The installer should do its work quickly but if it hangs, try the jdk 1.5.0
later...now it has completed the install process but is still not deploying properly.
As stated in the first panel of the installer, you have to manually change the tomcat's server.xml file.
Another option could be to install the supplied Jetty package and use the start/stop scripts inside the
bin directory.
