Tomcat 5 works well for me - on windows.
Here is my server.xml with both geonetwork 1.2.1 (on
http://localhost:8080/geonetwork) and beta2 (on
http://localhost:8080/geonetwork2) :
<Context
path="/geonetwork2"
docBase="C:/Application/geonetwork2/web"
crossContext="false"
debug="0"
reloadable="false" />
<Context path="/geonetwork" docBase="C:\Application\geonetwork121/web"
crossContext="false" debug="0" reloadable="false" />
Using MySQL for DB.
HTH.
Francois
-----Message d'origine-----
De : geonetwork-users-admin@lists.sourceforge.net
[mailto:geonetwork-users-admin@lists.sourceforge.net] De la part de Andrea
Carboni
Envoyé : lundi 25 juillet 2005 11:57
À : Gavin Fleming
Cc : GeoNetwork Users
Objet : Re: [GeoNetwork-users] resend: problem installing GeoNetwork
Hi Gavin,
can you send me more information? (Like the log/catalina.out file etc...)
Anyway, I think that the config file of tomcat 5 is a bit different from the
one of tomcat 4 (we are only using tomcat 4). In this case I cannot help
because we use tomcat 4 and I don't know tomcat 5.
Alle 09:38, lunedì 25 luglio 2005, hai scritto:
thanks Andrea, your tip got it working on
http://www.eis-africa.org:8080/geonetwork
I'm still struggling on my other server (Gentoo, Tomcat 5, JDK 1.4.2).
I've fixed the server.xml but it's still not working.
HTTP Status 404 - /geonetwork/
type Status report
message /geonetwork/
description The requested resource (/geonetwork/) is not available.
Apache Tomcat/5.0.27
conf # /etc/init.d/tomcat5 restart
* Stopping Tomcat ...
Using CATALINA_BASE: /opt/tomcat5
Using CATALINA_HOME: /opt/tomcat5
Using CATALINA_TMPDIR: /opt/tomcat5/temp
Using JAVA_HOME: /opt/sun-jdk-1.4.2.08
[ ok ]
* Starting Tomcat ...
[ ok ]
any more tips?
thanks
Gavin
SF.Net email is sponsored by: Discover Easy Linux Migration Strategies from
IBM. Find simple to follow Roadmaps, straightforward articles, informative
Webcasts and more! Get everything you need to get up to speed, fast.
http://ads.osdn.com/?ad_idt77&alloc_id492&op=click
GeoNetwork-users mailing list
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
distribution must be authorized.
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
