Hi Hugo,
One option is to help harvesters only harvest your local records is to use OAI's "set" query parameter.
To do so, create a GeoNetwork category (such as "Harvested-Not"), and to add all your non-harvested records to that category.
The OAI "ListSets" query
[host]/geonetwork/srv/eng/oaipmh?verb=ListSets
gets a response which lists all available sets
(the OAI "sets", within GeoNetwork, are the GeoNetwork "categories" ):
If the naming of the set is clear, harvesters will be able to guess what each set is.
The OAI "ListSets" response provides both the setSpec and SetName, for each set, e.g.
<setSpec>maps</setSpec>
<setName>Maps & graphics</setName>
Harvesters, using the OAI verbs of ListIdentifiers or ListRecords, can filter using the setSpec,
e.g.
[host]/geonetwork/srv/eng/oaipmh?verb=ListIdentifiers&from=2002-07-10&until=2014-09-13&set=maps&metadataPrefix=iso19139.anzlic
Kate
-----Original Message-----
From: Jose Garcia [mailto:jose.garcia@anonymised.com]
Sent: Saturday, 11 October 2014 12:11 AM
To: Hugo Ahlenius
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] restrict OAI-PMH queries
Hi Hugo
I don't know too much about OAI-PMH interface, but probably is similar to CSW to expose the metadata: any public metadata (allowed to group ALL) will be available to anyone using OAI-PMH interface without authentication.
Not really sure that can be managed additional filters to exclude for example harvested metadata, unless is not public.
Jose García
On Fri, Oct 10, 2014 at 2:24 PM, Hugo Ahlenius <hugo.ahlenius@anonymised.com>
wrote:
I am curious about one thing - I have a GeoNetwork node set up now,
with a mix of documents and data + a lot of harvested records.
Now, I would like to limit what data is being
published/queried/Accessed through the OAI-PMH interface to documents
and excluding all harvested records - how would I go about doing that?
Any comments and tips are welcome!
Hugo
Hugo Ahlenius
Hugo Ahlenius E-Mail: hugo.ahlenius(at)nordpil.com
Phone: +46 75 7575284
Nordpil Mobile: +46 733 467111
http://nordpil.com Skype: callto:hugo.ahlenius
Twitter: https://twitter.com/nordpil
vCard: http://nordpil.com/hugoahlenius.vcf
-------- Meet PCI DSS 3.0 Compliance Requirements with EventLog
Analyzer Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI
DSS Reports Are you Audit-Ready for PCI DSS 3.0 Compliance? Download
White paper Comply to PCI DSS 3.0 Requirement 10 and 11.5 with
EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.
clktrk _______________________________________________
GeoNetwork-users mailing list
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net/> for details. _________________________Jose GarcíaGeoCat bvVeenderweg 136721 WD BennekomThe Netherlandshttp://geocat.net/>*
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
