[GeoNetwork-users] rss.search & opensearch (GN 2.1)
The rss.search webservice in geonetwork always returns 10 records even
when I specify a from/to parameter.
Also, how does one activate the portal.opensearch service : --
<OpenSearchDescription>
<ShortName>GeoNetwork opensource | UNEP | Ecomundus</ShortName>
  <Description>
GeoNetwork opensearch service allow search to be made into the metadata catalog.
</Description>
<Tags>GeoNetwork Metadata ISO19115 ISO19139 DC FGDC</Tags>
<Contact>sean.khan@anonymised.com</Contact>
<Url type="text/html"
template="http://geonetwork.ecomundus.net:80/geonetwork/srv/en/rss.search?any=\{searchTerms\}&amp;bbox=\{geo:box?\}&amp;&quot;/&gt;
  <Image type="image/vnd.microsoft.icon" width="16" height="16">
http://geonetwork.ecomundus.net:80/geonetwork/favicon.ico
</Image>
</OpenSearchDescription>
sean
Best Regards,
Sean Khan
UNEP/IWLEARN Project Manager
P.O.Box 30552
Nairobi
Tel: (254) [20] 762-3271
From Europe and N.America, dial via Italy +39 0831 24 3000, wait for voice
then dial 124 3271
Hi Sean, the opensearch service is just a gateway to the rss search
service of GeoNetwork. You need to have a look to the rss.search params.
If you want to display more items, use the hitsPerPage param.
So you can edit the opensearch xsl to set a default number of hitsPerPage.
I think there's no way to use the from and to parameters easily with
rss.search. Maybe you need a two steps approach :
- first do a rss.search
- then a rss.present using the from, to params.
(not tested).
HTH. Francois
  <Description>
</Description>
</Image>
sean
Francois Xavier Prunayre
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)6 34 11 71 75
http://www.camptocamp.com
francois-xavier.prunayre@anonymised.com
