hi Doug,
in the Dutch INSPIRE portal project www.nationaalgeoregister.nl we have
moved several times from one server to another. We've always dumped the DB
content, than imported that into the DB on the new server. Using GAST to
export all metadata records will give you only that, but you'll want the
complete DB contents, including your users, groups and harvesting settings
etc.
After importing you may need to adjust some of the settings in the admin's
settings page, such as the server URL if you're not using a domain name.
The procedure to export and import the complete DB depends on what brand
you're using, but in general it should be a simple operation.
If you're also moving from one make of DB to another, the process may be
slightly more involved. For an example on how to move from a MySQL to a
Postgres DB, see the description at http://geonetwork.tv/postgres/.
Kind regards
Heikki Doeleman
On Wed, Oct 28, 2009 at 5:56 PM, Nutsch, Bob D. <bnutsch@anonymised.com> wrote:
Hi Doug,
In general, as you indicated, I too would use GAST to export then import
all metadata records. However, we've recently "moved" GeoNetwork from test
to production using the following steps (the text is from our developer,
Chris. H.):
It's the database folks that make it easy here. I put in a service request
to copy the entire schema from test to prod and it magically gets done.
If one is using the McKoi database that comes default with GeoNetwork, there
is some documentation for it here: http://www.mckoi.com. One should
probably switch to something like MySQL, as some of the other users have
done. Then, follow the backup/restore process for that database. The images
are stored on the file system and need to be backed up separately. We
haven't worried about copying the Lucene data, as rebuilding it hasn't taken
very long.
Our process for moving to production was:
Copy everything in the database to a production server. Copy the images to
the new server. Update various configuration settings and paths (I have an
Ant script to manage these settings)
Database connection info in GeoNetwork's config.xml to point to the
new database
GeoNetwork's host in the settings table (or in the ui)
GeoServer url in intermap config
Proxy base url in GeoServer's config
GeoServer's log file location
Regards, Bob
Bob Nutsch
GIS Coordinator
State of North Dakota
Phone: (701) 328-3212
www.nd.gov/gis
-----Original Message-----
Sent: Tuesday, October 27, 2009 12:56 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Saving and restoring GeoNetwork
It is not clear to me how one would backup and then restore a GeoNetwork
instance, say to move it from a development to a production machine or
to perform a restore in case of disk corruption. I see that certain
metadata files through a query can be saved by GAST, but not all files.
Moreover, one needs to save all configuration info for harvest and site
administration -- essentially all the data in the database and Lucene.
How have other users transferred full GeoNetwork instances from one host
to another?
Doug.
Douglas D. Nebert
Senior Advisor for Geospatial Technology, System-of-Systems Architect
FGDC Secretariat T:703 648 4151 F:703 648-5755 C:703 459-5860
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
GeoNetwork-users mailing list
